#217 |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
I can take some pics tomorrow. You need the back or front of the circuit board? I might see how hard it's gunna be to change the led's while I'm at it. Change the colors of my speedo and stuff.
My Car Rules! |
#218 |
Both sides if you can get at them. If not, some good macros of the IC's so I can figure out what they are and the pinouts of them.
#219 |
Damn, thanks for doing all this $hit man. I'll get the pics for ya tomorrow.
My Car Rules! |
#220 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Hmm I am old enough to be a dad lol ... and don't worry, it's a cheap-o one from crappy tire that has a metal 'needle' bar that you can easily bend back. I don't care if it breaks or not, I just needed a long breaker bar type deal, and since breaker bars here are ~$30, it was cheaper to buy a $9 torque wrench for the same deal.
#221 |
#222 |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Alright, so to make the OEM stalk work, how would it be different than what nickhjort is doing?
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
#223 |
#224 |
What about the extra wires I need? Any particular gauge or material?
Also - would I go about threading the wires through the steering wheel via the clockspring wiring? And on the stalk, which wire is which? I have a lot of questions because the majority of this thread was about adding buttons for cruise control, and the stalk was only talked about at the very beginning.
#225 | |
I would go with somewhere between 18 and 22 gauge. Insulation material is not critical. The wires are already in the clockspring, so you will just plug in the stalk connector when you pull off the steering wheel. On the other end of the spiral cable (at the connector shown below, next to the yellow one) you don't have the blue and brown wires in pins 1 (blue) and 3 (brown), so you will either have to find pins that fit, or solder the wires right to the connector's pins.
#226 |
I'm definitely missing something. Where do the additional 2 wires from D3 go? I mean, with the switch method for models other than the 09, it seems like you don't need to use D3. But since I'm going to be using the stalk, I need to use D3.
#227 | |
For the stalk method the wire from pin 40 of the ECM goes where the blue wire is above in D3. Where the brown wire is in D3, you will run a wire from that position to a ground point. |
#228 |
And I wouldn't need to bother with the clutch control switch then?
#229 |
You would still need the cruise clutch switch (if your car is MT). It connects from the clutch switch (which you would have to add) on the pedal bracket to the under hood fuse box. It is separate from the stalk and its wiring.
#230 |
PCB for 07 Hatchback
Here's those pics CTScott...hope they are good enough. If you need more I can take more tomorrow. I'm heading to work right now...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() \ ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sorry there's so many on this post, but I figured the more the better :) Let me know what you think. Like I said before, I feel pretty confident in my basic electrical abilities. I can solder to PCB's and all that fun stuff. I would rather not switch the switches around (since I just got them all done and looking good), but however I can get that light to light up I'll do it. Oh and also I have a 12V LED in there right now, only cause I had a bunch laying around. Let me know if I need a different voltage LED too. Thanks again. And I hope all this stuff is helping other people want to do this mod. I've spent less than $10 so far. $500 or $10...no brainer
My Car Rules! |
#231 |
Excellent pics! Let me scratch around them a bit and see what I can come up with.
#232 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Great work so far guys. |
#233 |
Well I'm your dummy ryank!
![]() And Thanks for scratching around CTScott. My car is all put back together for now, so I won't get a chance to work on it again till this weekend. In the meantime, lemme know what you think about the LED. Thanks a million!
My Car Rules! |
#234 | |
OK. To figure this out, we'll need the meter PCB to be hooked up to the car. What you'll have to do is turn the ignition on, and initially take 16 voltage measurements, then press your cruise on button and take the 16 again. If one of the 16 changes after turning cruise on, we'll know that that pin would drive the cruise LED if the car had one. IC500 and IC501 are the "8 bit shift registers". Each of them can drive 8 LEDs. We need to look at pins 3 through 6 and 11 through 14 on each. Pin 1 is the pin under the "1" after the IC50x label. In your picture which has the text upside down, Pin 3 is right above the middle of the 00 in IC500 and right above the 1 in IC501. In that view, 4, 5 and 6 are to the right of 3. Pin 9 is at the top right in that view (next to the upside down 9). Pin 11 is two pins to the left of 9. 12, 13, and 14 are to the left on 11. So, connect it up, turn the ignition switch on, and measure from a ground point to each of those 16 pins. They will measure ~0.5 VDC, or ~5.0 VDC. Then, press your cruise on button and measure all 16 again. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 02:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 07:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
