Old 05-07-2009, 05:23 AM   #1
liyux2k
liyux2k's Avatar
Drives: Vios
konig helium question?
hi, i'm looking to upgrade my steelies to konig helium 15 inch and i'll probally use my stock 185/60r15 tires is that okay? according to tire sites it's ok and i went on bridge stone site maximum for it is 6.5inch so i guess it might work anyone tried?
another question is i've read some reviews about the helium is it durable? also what is the official load limit? i know the tires have load limits but i know this sounds noob but what about the rim. is it the same as the tires or any site? links will be helpful thanks!!!
liyux2k is offline   Reply With Quote
Old 05-07-2009, 09:46 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
You can safely run 185mm tyres on wheel widths 4.5-7.0".
Old 05-07-2009, 09:28 PM   #3
liyux2k
liyux2k's Avatar
Drives: Vios
what about the load limit? i've found some used ones, what is important to inspect on them? i'm newbie never bought used before
Old 05-08-2009, 12:13 AM   #4
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
I just inspect for any major cracks. And make sure they aren't bent and their aren't any bulges on the outer lip. I'm not sure you really have to worry about any load rating. As long as it fits and there aren't any defects I'd say you're golden.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 05-08-2009, 01:33 AM   #5
severous01
ok...yaris is one of the lightest cars on the market....i'm sure that ANY load limit on a tire from any company would work fine. with that in mind....if you're still concerned now's the time to do a serious weight redux...
remove ANY trim, plastics, covers, seats, panels, or whatever you dont use...second step is to replace any solid steel piece with an aluminum piece.
third would be to cut every bolt that extends beyond the nut off....believe it or not i lost almost 100lbs of raw steel off my camaro which dropped me down to 2900lbs for a v8 car...pretty good if you ask me. an i was soo into it i even hole-sawed the interior that wasnt structural.
Old 05-08-2009, 04:55 AM   #6
liyux2k
liyux2k's Avatar
Drives: Vios
oh i'm not worried about lightening my car just hoping the rims can stand up normal day use like 5 people with trunk filled. =D
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
Konig Helium + Falken RT-615s installed (Pics!) schleppy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 04-26-2009 11:38 AM
Flint Mica S Sedan, Bronze Konig Helium, NF210 Springs, und Tint flint_mica_manual Photo-Video-Media Gallery 6 05-09-2007 03:25 AM
Konig Helium bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 11-26-2006 02:48 PM
KONIG HELIUM Ultra LIght Weight wheels C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 08-03-2006 07:00 AM
