Old 05-07-2009, 11:50 AM   #271
OK. I looked up your VIN / Model code (SCP90L). It looks like none of the European Yaris even have cruise as an option.
Old 05-07-2009, 12:24 PM   #272
I just verified with one of our members that works at a dealership in Europe, that cruise is not an OEM option on European Yaris. To add it a ~$500 aftermarket system is required.
Old 05-07-2009, 12:31 PM   #273
mariann
Drives: yaris 2007
holly cow!!!!
there isnt a way to jump few wires, cutting others and it will work?
like jumping to pin 56 at ECM?
mariann is offline   Reply With Quote
Old 05-07-2009, 12:42 PM   #274
Originally Posted by mariann View Post
holly cow!!!!
I don't think so. It looks like the ECM is just not even programmed to support it.
Old 05-07-2009, 01:00 PM   #275
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Damn that sucks dude. I'm sorry that it's not able to be done with your car. What if you get an ECM from a yaris like ours? Or will that even work...CTScott?
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-07-2009, 01:30 PM   #276
Not with his transmission. Also, even a used ECM would be more expensive then the aftermarket cruise kit.
Old 05-07-2009, 11:09 PM   #277
nickhjort
nickhjort's Avatar
I see...good to know :)
My Car Rules!
Old 05-08-2009, 02:38 AM   #278
regal
Drives: 09 Yaris 3 Dr White LB
is it possible to order the side cover piece from the factory with the hole already there? I am sloppy with a drill and dremmell and don't want a hack job.
regal is offline   Reply With Quote
Old 05-08-2009, 08:08 AM   #279
Cover, Steering Wheel Boss, Lower: 45184-52130-B0
This is for one that has the hole for factory cruise control.
Old 05-09-2009, 10:17 AM   #280
CTScott, I checked every pin (just to be sure) on those two IC's (IC500,IC501) and the pins for the blank spot where the third IC should go (IC502). Nothing :( they were all the same after I hit the Cruise switch. I grounded my meter to the frame and checked the pins with the red lead of the meter while it was on DC Voltage "20V" setting. That's how I do it right (I don't think I'm that dumb, but just to make sure) I guess it's not gunna happen the easy way as usual :)
I received the parts this week for lighting your LED, without changing your switch. I will be using a PIC12HV615 microcontroller to sense the switch press (and differentiate between the on/off and one of the other ones being pressed) and to drive the LED. The entire circuit will only require the 8 pin microcontroller, a transistor, and a few resistors (totaling maybe $5 in parts).
I will hopefully have some time this weekend to experiment. PM me your mailing address, and when I have it all figured out, I'll mail you the "module" (at no charge, since you've been the guinea pig for this).
Old 05-09-2009, 10:23 AM   #281
nickhjort
nickhjort's Avatar
Damn man that's awesome...PM sent.
Thanks so much for all the help with this project. It's not so bad being the guinea pig on something when you have so much knowledgable help on the subject. Hopefully we can get this thing hooked up and write up a nice DIY for the other "cruise control-wire-missing" drivers here :)
My Car Rules!
Old 05-09-2009, 10:36 AM   #282
mrbond
mrbond's Avatar
Alright, so just to sum it up for the stalk usage: I remove the airbag, install the stalk like in that Matrix link, then run a wire from the D connector to a ground point, and then the other wire straight to pin #40 in the ECM?
Do I mess with A21, or do I just do what I wrote in the above paragraph? (and this is all just if I don't bother with the clutch switch just yet)
- A Toyota Yaris
- A whut Yaris?
Old 05-09-2009, 11:32 AM   #283
Correct.
Remember that in order to even test it, you will need to bypass the clutch switch at the under hood fuse panel connector.
Old 05-09-2009, 11:37 AM   #284
mrbond
mrbond's Avatar
^ right, you said to jumper it to the white wire 2 pins over? What do you mean by jumper?
- A Toyota Yaris
- A whut Yaris?
Old 05-09-2009, 01:13 PM   #285
Basically, make the connection. Since it is temporary, until you get the switch, I would just shove a stiff piece of wire from the blue to the white.
Old 05-09-2009, 03:09 PM   #286
mrbond
mrbond's Avatar
nickhjort, did you find any connector for the wiring to the clutch switch? Been searching for it for a few hours and haven't found anything. I believe that only the 09+ mt Yarii have that plug just hanging there...
Also, what is the function of the white wire you jumped the blue clutch switch wire to? Did you just do like what CTScott said and stuffed one wire into both pins?
- A Toyota Yaris
- A whut Yaris?
Old 05-09-2009, 04:30 PM   #287
nickhjort
nickhjort's Avatar
Yeah basically I just used a thick guage wire I had laying around, that just happened to have a fuse on it, and just stuck it in there. You probably don't need the fuse, but what the hell...you can never have too many fuses right :) And no I didn't find the clutch switch connector under there either. I am still going to buy the stock switch though and just wire it to where I have the jumper in the fuse box. Basically what the switch does is acts as the jumper wire...only it's a reversed switch. So when you hit the clutch it kills the circuit (just like if you were to pull the jumper wire while using cruise control) Here's some pics of my jumper. Also make sre you put some spade connectors on the ends of your wire. They fit in there perfectly, nice and tight to ensure it doesn't come loose.
Hope it helps
My Car Rules!
Old 05-09-2009, 04:31 PM   #288
nickhjort
nickhjort's Avatar
PS... Make sure whatever you use as a jumper will fit under there whenever you put the fuse box cover back on :) Mine just barely fits.
My Car Rules!
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
