Old 05-08-2009, 04:43 AM   #1
nisyota
High Flow Catalytic Converter
Has anyone installed one? If so, what kind and did it improve any performance, like mpg :D ?
I want to install the set-up like Marcus with his magnaflow... they sound nice and its not too loud... I like to have a nice smooth exhuast... :D
nisyota is offline   Reply With Quote
Old 05-08-2009, 04:48 AM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
i have one. it's a magnaflow 2.25" hi flow cat. 12" long. used it to quiet down my header back exhaust, and it did. however, i only have the hiflow cat and a 18" resonator. can't help ya with any info for the mpg department.
http://www.jegs.com/i/Magnaflow/642/54305/10002/-1
Old 05-08-2009, 12:22 PM   #3
severous01
you should look into random tech cat's. it's a pipe...that catalyzes the exhaust. its just like a straight pipe, only emissions legal.
Old 05-08-2009, 06:18 PM   #4
fuji
fuji's Avatar
Drives: Polar White Yaris HB
I thought changing the cat converter was illegal. Is there any way to do it legally or does it even matter?
fuji is offline   Reply With Quote
Old 05-08-2009, 06:23 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
each state varies.
it's illegal to remove a cat from your vehicle, but if you replace it with another cat you may be in the clear. if your state does not do emissions testing then you're definitely in the clear. i'm running a magnaflow spun cat as well.
Originally Posted by xnamerxx
you nailed it sir.
Old 05-08-2009, 07:13 PM   #6
gwasabi
Drives: 07 Blazing Blue LB
In Hawaii, Not having a cat is Illegal. Replacing it is not. WE don't have Emission testing though...
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-09-2009, 04:47 AM   #7
fuji
fuji's Avatar
What are the benefits of changing the cats - more horsepower?
Old 05-09-2009, 05:23 AM   #8
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
High flow Cat > OEM Cat
main thing is being able to be legal when it comes to state testing...and doing your part in being more green.
If you want more horses, go straight pipe to muffler. BUT you will no longer pass any state inspections or testing, and you can get popped my local law enforcement if they check to see if you have done a cat delete.
Old 05-09-2009, 05:38 AM   #9
YarisSedan
Drives: 08 Yaris Sedan
High flow cat isnt really even a cat its just a strait pipe that has catalist around the inside it maybe has 5-10 percent of catalist that a normal cat would have. Also is not smog legal anywhere.
Old 05-09-2009, 05:28 PM   #10
eric81
eric81's Avatar
Drives: Toyota Salesman
No one said if they had or even noticed any power increase. Or even if it maybe just helped the engine rev up a little quicker.
eric81 is offline   Reply With Quote
Old 05-09-2009, 06:22 PM   #11
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Well, Maine has no smog testing or emissions test at all, so that would be sweet for custom
Old 05-10-2009, 12:01 AM   #12
severous01
wanna bet??? i had better emissions on my camaro with the random tech than oem.
Old 05-10-2009, 12:53 AM   #13
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
I dont have any dyno numbers but when I installed my nitto mid-pipe with "cat delete" I could feel a slight differnce , mabey good for 1-3 real hp's .
Old 05-12-2009, 04:37 AM   #14
nisyota
you guys are also installing 2.25" pipes on these cars? But isn't 2.25" a little too big? Whats the stock diameter of the exhaust pipes?
Old 05-14-2009, 05:15 AM   #15
PETERPOOP
PETERPOOP's Avatar
I am running 2.25" from the header back; but i have the blitz s/c kit.
Old 05-14-2009, 05:30 AM   #16
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
1.75"
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 05-14-2009, 12:12 PM   #17
nisyota
Originally Posted by sf180th View Post
1.75"
thanks...
Old 05-14-2009, 03:33 PM   #18
YarisSedan
Sorry but putting something in that has lower catalist efficiency and less catalist will not magically make the emissions out of the tail pipe cleaner.
Its called the law of common sense. Now if its on a car that has already extremely clean emsisions and you delete the cat you may not see much change in emissions but definately wont see a improvement.
TRD High Flow Oil Filters Jansen DIY / Maintenance / Service 20 05-25-2009 05:36 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
New CAT Converter story.... jlift DIY / Maintenance / Service 14 06-03-2007 02:23 AM
High-to-low converter Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 11 05-21-2007 02:18 PM
catalytic converter question SamDaYarisMan Performance Modifications 14 09-08-2006 11:18 AM
