![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
Custom 1.75" catback exhaust - worth it??
I had a 2" custom exhaust installed not to long ago. I was hoping to see a bit more oomph in the mid to upper ranges but the results have been slightly diappointing. I definately noticed the lack of oomph in the lower end.
I know most people would install a 2" or 2.25" piped exhaust but is there a way to constuct a free-er flowing 1.75" that would restore the lower end oomph while giving some benefit up high as well? Any difference in power when adding resonators and high flow catalytic converters? Just better not to run a resonator???
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
leave it at 2 and get corolla tb
Is it a CAt delete?
Most Satisfying Crew Serious Business... MunkyWurks Garage - 8088488794 |
Also, if you have a pulley set, you might want to change back your CRANK PULLEY to OEM. I noticed that the torque kinda sucks on the lower end with it on
The cat is currently in place. Is there any advantage to having a hi flow cat installed???
Keep the cat if you want the backpressure.
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| Custom exhaust or pre-made exhaust - which one makes more power? | fuji | Performance Modifications | 9 | 03-08-2009 12:24 AM |
| Custom Cat-Back exhaust Yaris TS | CASTREX | Yaris TS Talk | 16 | 10-24-2008 12:56 PM |
| Custom Catback System | Sabretooth | Performance Modifications | 48 | 07-10-2007 09:59 AM |
| Catback exhaust? | elsteverino889 | Performance Modifications | 5 | 03-09-2007 10:55 AM |
