Old 05-06-2009, 04:54 PM   #91
gwasabi
Drives: 07 Blazing Blue LB
Just keep driving with the lights on eventually it'll go away
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-07-2009, 12:03 AM   #92
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
just turned off again
so hopefully it stays off at this point
You are just getting a CEL correct not a CEL + oscillation?
Old 05-07-2009, 02:37 AM   #93
gwasabi
Thats probably due to the Coolant just drive around for a bit and let the coolant settle. It'll eventually just go away
Serious Business...
Old 05-07-2009, 04:28 PM   #94
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
I FORGOT AND AM TOO LAZY TO REREAD DID YOU DO THE CHIP SWAP AND WHICH TB WAS IT AGAIN AND YEAR...
Old 05-07-2009, 04:56 PM   #95
gwasabi
No I didn't do the chip swap I don't think kustom play did either
Serious Business...
Old 05-08-2009, 10:49 AM   #96
Yoda
Yoda's Avatar
i can not find it on ebay.....LAME
Old 05-08-2009, 08:03 PM   #97
PHXDEMON
PHXDEMON's Avatar
Dammit mine started oscillating again and hard No CEL just hard oscillation like 1-4k rpm while driving.
Old 05-08-2009, 08:42 PM   #98
Yoda
Yoda's Avatar
wo wo wo wo thats not sexy
Old 05-09-2009, 05:07 PM   #99
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
That was my issue I just said fuck it and sold it.
Old 05-09-2009, 05:59 PM   #100
PHXDEMON
PHXDEMON's Avatar
Yeah I think I might do the same It sucks because on wednesday it ran flawlessly to work and back and then it just started happening again for no reason. I really want to figure this out and get it fixed though because there is definately a big power difference with it on. Did your oscillate randomly or is it like mine where sometimes you start it up and it runs fine but sometimes you start it up and it immediately starts oscillating?
Old 05-10-2009, 12:21 AM   #101
PHXDEMON
PHXDEMON's Avatar
this is what you should do, seems to work for mine
unplug the battery for about 4 hours
chip swap the TB
do the coolant bypass
plug battery back on start car
wait about 5 mins to oscillation so settle down
step on the gas to make the car think your driving it, hold it at like 5K RPMS for about 5 mins (mine started to oscillate again, stopped let it settle and did it again for 2 more mins.
let car idle for 5 mins
shut car off, let it cool down for a few hours
open radiator cap
start car up wait for bubbles to come out and fluid to just about overflow then put the cap on, putting cap on should cause the coolant to come out at that point, wipe up spilled coolant.
drive around , my CEL went off then came back on the went back off but seems to be off now.
but i never had oscillating anymore using this system
I did the coolant thing but didn't let it overflow I'll try that. so 5k rpm for 5 minutes. Poor little car Oh well that bitch deserves it for doing me wrong by oscillating We need to arrange a Yaris meet so I can see your pink wheels
Old 05-10-2009, 12:23 AM   #102
PHXDEMON
PHXDEMON's Avatar
Also I don't see how the coolant thing could cause oscillation with the TB coolant bypass done. Anyone care to elaborate?
Old 05-10-2009, 01:40 AM   #103
gwasabi
With a bypass it shouldn't oscillate if it is its just the Throttle being wierd
Serious Business...
Old 05-10-2009, 03:26 PM   #104
jmew0ng
Drives: Scion FRS
wait till I install my TB till you guys get a meet lol... (i'm just going to install after finals are over).
it seems like there's just 3 of us from phoenix on here
For the chip swap did you just use a new set of nuts and bolts?
and what did you guys do to get the rivets out?
jmew0ng is offline   Reply With Quote
Old 05-15-2009, 07:07 PM   #105
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That's awesome... On to the next CEL-inducing mod!
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Gentex K31 - auto dimming mirror w/ map lights, compass, outside temp. -- installed. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 22 01-06-2009 07:34 AM
ambient map lighting? atebit Cosmetic Modifications (Exterior/Interior) 0 11-05-2006 01:15 AM
