Where is Oahu?
I bought the blitz throttle controller because I wanted a more sensitive acceleration when the pedal was pressed.
Some info off the blitz web site: Recent trend of automobile equipped with Electric Controlled Throttle Valve replaced from Mechanical Throttle Valve (Cable type). The electrically controlled throttle valve is one of updated technology in automobile industry and the technology brings a precise throttle valve control enable to adjust acceleration characteristic for much more fuel conservative yet causing gap in acceleration response in the other end. BLITZ Throttle Controller eliminates acceleration gap as much as possible by converting electric signal by the use of pre-programmed characters (modes). Throttle Controller is an item which improves acceleration response. The unit includes Vehicle Specific Wire Harness, which makes Plug & Play easy installation (some vehicle may require 12v power wiring). Most application simply plugs in Vehicle Specific Wire Harness in between a accelerator-pedal position sensor and a factory stock wiring which is most of time located close to accelerator pedal. Display Units and Control Box are separated individually made display unit light and compact enough to place easy on dashboard area. BLITZ Throttle Controller is a most reliable unit among in the market as well as an easiest solution to improve accelerator response. Picture of Blitz throttle controller ![]() Plug on top of the acceleration pedal that I'm connecting to. I put a mirror on the side of the plug so you can see how to take the plug off. ![]() Plug off. Took it off with my hand, it was a little hard to take off, but I eventually unplugged it. ![]() Blitz plug connected to the top of acceleration pedal ![]() Other Blitz plug connecting to the other plug that comes from the car engine. Sorry, I don't know what to call the plugs, but it's pretty self explanatory. ![]() Installed ![]() From there, plug the plugs into the blitz module. I positioned the module behind my AC contols. ![]() *******IF INSTALLING THE REVERSE CANCEL HARNESS********* Reverse cancel harness comes with a pink wire about 10 feet long. It's optional, but I'd highly recommend it because I did not want my acceleration pedal to be jumpy when reversing. I basically connected the pink wire to the module, the manual shows which pin to input the wire. I then ran the wire to my positive side of the back left reverse light. I tried to locate where the reverse wire was in the car, since I was lazy, but played it safe and ran the pink wire to the reverse light in the back. Pics are below Driver's Side front door ![]() Driver's Side back door ![]() Trunk ![]() I tapped into the reverse light in the back, but forgot to take a pic. Position the controller wherever is most convenient for you, and enjoy!! Modes for Controller eco-better to use this for daily driving sp1-feel the acceleration at startoff-good for regular driving sp2-medium acceleration at startoff-good for medium driving sp3-jumpy acceleration at startoff-good for highway use Last edited by 808_Yaris; 05-11-2009 at 03:15 AM. |
toyota
messy on the reverse cancel wire...but how was the drive..and how much did you get it.
![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
How expensive are these again? Did it really make that much of a difference?
toyota
$420 usd on the website but maybe cheaper somewhere else..
sprint booster is $320 canadian but no adjustments and cancel wire. |
For 420 bucks it better suck my dick
Where is Oahu?
Where is Oahu?
#9 | |
the reason I still haven't bought it yet as because I thought it was pluging into the OBDII, and I can't live without the GReddy Informeter Touch(which plug into the OBDII) Now, it is the next upgrade I MUST get
Where is Oahu?
やりすぎだ~
This thread should be titled DIY: Blitz Throttle Controller.
What are the different modes? I noticed ECO (which is probably stock) and then there are SP1, SP2, SP3. What are they like? Have you tried those out? |
I'll have a couple of these in stock this week in case anyone is interested
#14 | |
Where is Oahu?
eco-better to use this for daily driving sp1-feel the acceleration at startoff sp2-medium acceleration at startoff sp3-jumpy acceleration at startoff-good for highway use you have to understand that if you plan on using the highest setting. it will burn gas!
Where is Oahu?
やりすぎだ~
haha! Yes, clearly understood. But with all those mods, who's concerned about gas? So is "eco" same as stock?
Where is Oahu?
eco is a little better than stock. i still notice a slight difference.
toyota
hmm i wonder how much garm will sell this..with cancel wire...pricing pls..
| Question about Blitz Throttle Controller | AlainMikli | Performance Modifications | 20 | 12-10-2010 03:00 PM |
| blitz throttle controller does it work.. | marcus | Performance Modifications | 39 | 06-21-2009 07:40 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| For those with Blitz Throttle controller... | mastaofdisasta | Performance Modifications | 0 | 12-28-2008 08:26 AM |
| toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 12:03 PM |
