Old 10-21-2006, 04:56 PM   #55
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by H8SGAS
YEAH!!! I thought I was the only dope running around at night/early morning with no tail lights on! Several times I have got into the car all sleepyish after work, then I see my "head lights" so I'm not thinking they are not actually on! Exactly the reason I'm pulling my box too, before "The Man" gets me too
I did the same damn thing many of times, also why I disabled my DRLs... also so I can have just my blue LED lights light the headlamp area with out the Headlamp being on
Old 01-23-2007, 11:06 PM   #56
mutatio
Drives: Flint Mica AT Sedan
ok, a little bit of a flip of the topic, but would anyone consider sending/selling this module my way? feel free to PM me if so. :) i actually prefer DRL and wouldn't mind the insurance discount either. any reason why this wouldn't work on my sedan?
mutatio is offline   Reply With Quote
Old 01-24-2007, 10:32 AM   #57
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Your car needs to be pre-wired from the factory at least, to have the DRL's.
Maybe poke around online, and see. I remember all my BMWs came pre-wired for lots of things.
Old 01-24-2007, 11:04 AM   #58
Treyz
~ ambient one ~
Treyz's Avatar
What Kelven HID's are those .. just curious. I have h4 from my old 240 but one ballast went bad (Philips). Now is there a switch to turn on and off the DRL's? I know in my girl's mother's Trailblazer, there is that option. If not, is there an online FSM that can let me know where the remote wire is so I can just create one without taking out the box?
Reason being is that I do like the idea of the DRL. This way I can just have the switch off and then after I start the car, turn them on.
Yeah yeah before i go you're probably asking yourselves why the hell is a Noob going to go through all of this when he can just pull out the box and do what Chris does? It's because I'd rather have just the headlights on (like DRL's) and them on only until I have to turn all of my lights on at night.
I know it may seem like a PIA job to go through all that but I like challanges >:)
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 01-27-2007, 05:38 PM   #59
Chris07LB
Chris07LB's Avatar
Glad to help.
Old 01-31-2007, 11:55 AM   #60
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
DRL question!!
im actually wondering about its wiring could you just cut the wire going thru the drl should be just one of each side then re ground them and still ran it thru a separate bulb.. just a thought..it separates them from ur hid...
Old 01-31-2007, 01:36 PM   #61
Chris07LB
Chris07LB's Avatar
Then where would you mount an extra bulb at? Seems like a lot of trouble, to keep DRL's.
I drive during the day with my HIDs on, as its quite a little car we drive, and its bad enough A-Holes dont see you...
Old 02-01-2007, 11:18 AM   #62
marcus
toyota
marcus's Avatar
well i always thought its not always good to have the hid on due all the time due to its life hours.. then again im not an hid expert...sucks that i read that you lose ur high beams as well...dang...
Old 02-01-2007, 12:10 PM   #63
Chris07LB
Chris07LB's Avatar
FYI they make high/low H4 HID kits.
I chose to go with only a low beam H4, and turn my fogs into high's like Violin did.
Old 02-01-2007, 05:14 PM   #64
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Originally Posted by argylesocks View Post
call me a dork... but i like the DRL. i have hurd all the reasons before... but for me, i like 'em. i cant stand it when im driving at dusk, in the rain, and some moron is driving around without thier lights on. i can barely see them. if they had DRLs, it wouldnt happen. i dont want to be that moron that people cant see because i forgot to put my lights on....
Nobodys advocating driving with your lights off. But to save your aftermarket HID's you must dissconnect the DRY relay. You can still switch your headlights on during the day if you want, your just not obligated to.
PetersRedYaris is offline   Reply With Quote
Old 02-01-2007, 06:43 PM   #65
Treyz
~ ambient one ~
Treyz's Avatar
what about what I mentioned in the last page? Is there a way to just switch it instead .. I'd rather have the option of whether I want to have DRL's or not (comes in handy when trying to be stealth at night).
AMBIENTLIFESTYLE
Micro Image
Old 02-22-2007, 11:20 AM   #66
marcus
toyota
marcus's Avatar
chris drl question
now disconnecting drl relay.. is it possible to hook that up to fog lamp instead..so fog light are always on and use that as my drl instead!!...
Old 02-22-2007, 12:02 PM   #67
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I don't know if anyone has figured that one out, but it wouldn't easy as it would involve fiddling inside the ECU.
Why not just run a line from a switched circuit to the fog lamps so they come on whenever the ignition is switched on? Use a blank circuit or trigger a relay from an existing circuit and run a wire (fused) from your battery.
Old 02-22-2007, 03:26 PM   #68
barryware
Do you speak from experience?
With the DRL's disabled, and the parking hand brake in the up/locked position, the brake light in the dash cluster DOES light up. Engine running or not, headlights on or off. When its in the down position, the lights off.
Weird that your is different.
Sorry about that... I was wrong. When I saw the wire from the DRL relay to the parking brake in the wiring diagram, I assumed it was the same as my VW. In reality, the DRL's don't come on until the parking brake is disengaged. That's what the connection is for. Oops...
barryware is offline   Reply With Quote
Old 02-23-2007, 08:18 AM   #69
elsteverino889
elsteverino889's Avatar
Drives: 2007 Yaris sedan black
YOU GUYS GOT DRL's! WTF I WANT DRL's...i didnt know the liftbacks had that w/e
elsteverino889 is offline   Reply With Quote
Old 03-03-2007, 09:12 AM   #70
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
did my disable last night, now im stealth......
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 03-03-2007, 09:41 AM   #71
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Easiest Mod My ASS!
There is a Metal bar that surrounds my DRL Relay… I put my hand in under it to pull out the White plug…
AND I FUCKING CUT MY THUMB… Pretty fucking deep too!
Now it seems all I need to do is droll on my-self a little
AAAAhhhdduuuuhhhhhhhhhh
But at least I got it!
Nutzoids is offline   Reply With Quote
Old 03-03-2007, 10:08 AM   #72
Violin
Violin's Avatar
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
