The LittleBastard
Drives: 2007 Yaris Liftback Join Date: Sep 2006
DIY: Groundwire Kit
Recently purchased a groudning kit of of ebay, and thought I'd share my install with those interested.
Here is the kit I purchased: http://cgi.ebay.com/ebaymotors/JDM-G...7988QQtcZphoto This is what was included in the Kit: ![]() Photos seem to be the easiest way for people to understand an install, so I'll be using mainly the photos I took during the process for this DII. Start by removing the stock negative terminal and replacing it with the one included in the kit. Now when you remove the stock terminal make sure you only remove the battery terminal adaptor. Leave the factory begative ground wire in place, it will be used wih the new terminal adapter that comes with the kit. ![]() sorry I don't have other angles of the terminal set-up, but it's easy to figure out so don't worry. Now you don't have to follow me as far as my connections points. You can choose to connect to anywhere you'de like, but here is how I started: ![]() Connection point from terminal to this point. ![]() second wire: ![]() this is even easier to figure out, but just incase here is a closer view of it connected to the throttle body. ![]() Third grounding point: ![]() from there I lead the third wire to this point. ![]() Now you'll move on to wire number 4: ![]() here is were I connected it to. ![]() fifth wire: ![]() heads down to the tranny, and this is the only mounting point which I did not use a factory nut to mount. Had to use one of the 10mm bolts supplied with the kit. here is the point. ![]() sixth point: Now remember that not all wires need to be connected to the terminal as long as they are grounding to either the vehicle or go off one of the other ground points. Here is how I grounded my sixth wire. ![]() the wire then goes around to the back and downward where I mounted it to here. ![]() seventh and final wire. What I chose to do was start off from where I connected the fifth wire. here it is connected. ![]() Now from there I lead it around the front and towards the back from underneath the engine like this. ![]() remember you have the option to connect it somewhere else, this is only the area I chose to connect to as it was the farthest from all of my other grounding points. I also tried to leave the least amount of wire hanging as you can tell in the pic above, just incase there is possibility of it getting caught on something. I actually got the wire to sit higher then the bottom of the front bumper. Now here is my final connection point. ![]() And there you have it, your car is now very well grounded. Before putting the engine cover back on make sure to zip-tie any wires that might need to be held away from certain area, or just to keep some from moving around to new locations. Once again here is the final product once it's all put together: ![]() Nice, clean finish.
Yaris Mods: 20% Tints Ground wires 2007 Toyota Yaris Liftback - Current 2004 Honda S2000 - Sold 1986 Toyota Corolla SR5 - Sold DIY: Groundwire Kit Last edited by ItsMyDaily; 10-24-2006 at 02:55 PM. |
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
Nice write-up. I will def be adding it to the manual.
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
QUESTION: Is it necessary to ground the tranny, no matter if it is manual or automatic?
Should I ground my amplifier as well? cheers-
20 years... alive and kickin'!! ![]()
#4 | |
The LittleBastard
Yaris Mods: 20% Tints Ground wires 2007 Toyota Yaris Liftback - Current 2004 Honda S2000 - Sold 1986 Toyota Corolla SR5 - Sold DIY: Groundwire Kit |
#5 | |
The LittleBastard
10-4
this is really nice and interesting :)
Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
Hey looks nice!
Just wondering, what gauge or AWG wire did this kit come with? It looks like 4AWG from the photos, but I'm not sure.. Edit: Beautiful pictures ItsMyDaily - thank you very much. This should make anyone's grounding wire DIY install MUCH easier!
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
That is super clean... not bad for 22 bucks shipped to your doorstep.
Only 22$?Damn this is cheap!
#11 | |
The LittleBastard
The LittleBastard
guys the price is really cheap for the quality of the kit. I was hesitent at first, and thought when it came in it was going to be a bad purchase, but the it is very nice. It always amazes me how some people will buy name brand grounding kits for hundreds of dollars when all brands include the same parts, and do the exact same thing.
I'm yet to drive the car to give my impressions of the kit. It'll happen soon :)
The LittleBastard
Just got back after a 20 minute drive. There is one word I think of to discribe the feeling of the car after the groundwire instal........"Smooth."
I am actually amazed that it did as much as it did, but at the same time I kind of expected it to do so when I saw that the Yaris motor has almost no grounds from the factory. The very thing I noticed is that the initial acceleration is a lot better. There is no delay in the pedal like there was before(although it was a slight delay before). The second thing I noticed was how smooth the engine felt as it climbed in rpm. The power felt very nice, and some how I find that there is less engine noise. The third thing I noticed was the transmission. Keep in mind that I have an automatic. The shifting is a lot smoother and feels almost as if it is one endless gear with no shifts. Even downshifting using the pedal feels smoother. Fourth thing I noticed, and my favorite part, is that I found myself pressing on the gas pedal less then I usually would. The car seems to have picked up some bottom end umph which requires less pedal movment to get it moving up to speed faster. I believe this will help in fuel efficiency. I think what has happened is the power and torque curves are now much smoother and power may even be coming a little ealier. This is the only way I can explain what it is I am feeling. Is there a chance that all of this is just in my head? Yes ofcourse there is. Who knows? I don't think it's all in my head. Either way for the money this is a great mod to have done. I'll let you guys know how it helps wih fuel economy once I reach my next fill up.
INTERESTING
I'll be buying this soon. The blue matches my shocks. HA! |
#15 | |
The LittleBastard
Cause everyone is looking at your shocks.Your right though this is also a nice engine dress up piece. I'm sure it'll look even better once I go ahead and order a blue aem cold air.
Hey, attention to detail is the difference between a nicely done CAR and just another rice rocket.
#18 | |
The LittleBastard
| For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. | TRD_Yaris | Items for Sale by private party | 6 | 05-06-2010 06:43 PM |
| Bluetooth Kit Info | so40 | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 07-12-2009 05:13 PM |
| Is aftermarket HID kit legal (in NJ)? | Jfoofoo | Cosmetic Modifications (Exterior/Interior) | 25 | 03-19-2009 02:05 PM |
| DIY KEYLESS ENTRY on Power Liftback? | TC-LIFTBACK | DIY / Maintenance / Service | 0 | 08-23-2006 09:57 AM |
| Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? | tifosi360 | General Yaris / Vitz Discussion | 9 | 08-07-2006 02:43 PM |
