5W20 or 5W30?
So I got an oil change the other day and the guy asked what oild I wanted, I told him 5W20 (which is what was in it since the day I got it a year ago), he wrote down 5W20, but then he put in 5W30. Is there any concern/problem running that or should I go back a bitch up a storm and make them switch it out? I only ask because it seems to be bogging down when I accelerate since then. Thanks for the help.
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
I don't think the 30 versus 20 will be a real problem. And rather than go back and complain, I just wouldn't go back. Take your business somewhere else.
If you are absolutely sure, its not just your expectation that is making it feel bogged down, check your level after a day or two. It should be between the marks on the dipstick and not over the top one. Someone who mixed up the weight without really looking, could have easily overfilled it with 4 or more full quarts instead of the 3.3 you needed. |
Yeah, they easily put in 4 qt's in my engine as well, and I am now going to switch to AMSOIL or Royal Purple now, and do it myself. They were supposed to put in 5W-20 in my engine, and use synthetic. I am pretty sure they did neither. So, I am selling back the prepaid maintenance and do it myself.
toyota
our yaris need 5w-30.. canadian..
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles" Join Date: Apr 2009
I thought 5w-30 is what's recommended in our cars. In fact, it even says it on the oil filler cap. In hot areas or high altitudes (Colorado) I would think the 5w-20 would be too thin to fully protect the engine.
I know some people advocate 5w-20 for a little better fuel economy, but I would rather have my engine protected with 5w-30.
2009 Absolutely Red LB. "Bubbles" Last edited by The little red pill; 05-11-2009 at 05:13 PM. |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
That's what my manual specifies.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
toyota
5w-30 is also on the oil cap but i believe usa got an update for them to be able to use 5w-20..
This was the first oil change not at the dealer, dealer has always put in 5W20. Will check the level for sure, kid who did it had me outta there pretty quick...could have screwed up.
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
The 08 car is supposed to use 5w-30 not 5w-20. You guys are misreading the TSB which I will say is poorly written and makes it confusing. Right at the top of the tsb EGO18-06, it says at the TOP in a big RED BOX, 'NOTE: to use what the oil filler cap says or the owners manual or the Maintenance manual for you year/model!' The tSB is saying that toyota recommend GF4 oils now (not ILSAC GF3 - the factory fill) and that newer models are transitioning to 5w-20. BUT NOT THE 08! Re-read the TSB and tell me which part you dont understand. I have not called Toyota to get this clarified, as I tried 5w-20 Mobil1 and the engine made so much racket I dumped it in 15 minutes of putting it in.
So not to be an ass ... Hey, if your car runs quiet and smooth and gets good gas mileage, running the the 5w-20, stick with it! You got an out with the crap TSB. I would verify with the selling dealer service manager though and get it in writing on a R.O. in the system.
SIPNDEW
when in doubt....read the cap
i have called toyota and was told that my 2008 sedan was factory filled with toyota 5w30 petroleum oil and recommend 5w30 petrol oil not 5w20. i too will not sacrifice engine protection for 1 or 2 mpg. as it is my yaris which has 21k mi now overall avg mpg is 43.6 my last 2 tanks were 48 mpg
Isn't the engine the exact same in 08's and 09's? The 1NZ-FE 1.5l engine? They changed absolutely NOTHING between the years, and you are allowed to use a different oil? Probably the same guys who decided to put two air filters in, or make the muffler enter and exit the same side... NO SENSE AT ALL!!! I am switching up to Royal Purple for engine oil and gear oil. Protects better and lasts longer.
Royal purple? Why? It not even synthetic? Why pay $$$ for non-synthetic, you like given your money to da man?
#14 |
Try THIS:
#15 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
However, I've been running 5w20 for 40k miles now and it has done just fine so I'll stick with it.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#16 |
Royal Purple has been proven time and time again to improve horsepower in cars by about 3% on average. It is in Car & Driver, Mustang Magazine, Speed, and several others. Simply changing out the oil's from whatever they are to Royal Purple improves HP by 3%.
#17 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Royal Purple FTW... its the only oil i used in my car...
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
#18 |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
There is nothing wrong with Royal purple, its far better then most big brand name group III synthetics like Castrol and Q state etc.
However Royal purple regular oils are all still group III synthetics made from crude/mineral oil. Only thier racing oils are group I~IV
The early bird gets the worm, but the second mouse gets the cheese. |
| FS: 8 qts ENEOS 5w30 | 1stToyota | Items for Sale by private party | 3 | 10-30-2008 07:29 AM |
| 5w20, My .02 | Turbo&Auto | DIY / Maintenance / Service | 23 | 07-15-2007 06:31 PM |
