Old 05-23-2009, 08:13 PM   #19
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I suggest getting your skill level WAAAAY up before driving a MR2 or Elise spirited . With these cars having the engine in the rear , it makes them susceptable to snap oversteer (especially in the wet ). The Elise is less susceptable than the MR2 due to the better tuned suspension , stickier tires and lower center of gravity . But even the mighty Elise will spin in the hands of someone who isn't up to par with their skills .
Old 05-24-2009, 02:26 AM   #20
jkuchta
Drives: 2007 Yaris hatch (red)
This car responds to very slight differances in tire pressures front to rear...
Just like Tomago and Loren said, play with that first.
I was able to dial out all of the understeer with completely stock suspension and no swaybar by running the rears like 3-4 psi higher than the fronts (34psi front, 38psi rear HOT). The car would pivot really nicely, and slight moments of oversteer were very controlable (i.e. a ton of FUN!).
I was running on 500 tread wear street tires, so the higher pressures were needed to keep the car off the sidewalls (though a trip to the Streets of Willow proved that there's really no way to keep a car that's driven hard off the sidewalls of a set of street tires, no matter how high the pressures are!)
The addition of a rear swaybar, better tires, and stiffer springs and shocks would have allowed more equal (and lower) tire pressures, as well as way more grip.
Tire pressures are one of those things you can play with a lot at the track, and it takes almost no time...yields almost instant feedback....and costs nothing...just don't change pressures more than 1-2 psi at a time.
jkuchta is offline   Reply With Quote
Old 05-27-2009, 12:08 PM   #21
regal
Drives: 09 Yaris 3 Dr White LB
What about pure potential, I heard 1g. With my trd shock, tokico blues, and rear sway bar I'm just not seeing it. It tends to dive into oversteer. There must be more potential out of this car.
regal is offline   Reply With Quote
Old 05-27-2009, 12:13 PM   #22
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
You can do anything you want with the suspension, if you don't put good tires on it, you're not going to pull a lot of G's.
Old 05-27-2009, 12:16 PM   #23
Tamago
Tamago's Avatar
Drives: UZJ100
beating a dead horse here, but you bought crappy tires lol
Old 05-27-2009, 01:54 PM   #24
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
someone posted an article about achieving 1g or greater in some tests, and the only reason the yaris seemed to pull it off was very specialized, and probably expensive, track-only tires. the suspension mods they did (perhaps minimal but I believe it was coil-overs) acheived .86g from the stock .75 without the tire change.
Old 05-27-2009, 01:56 PM   #25
scape
scape's Avatar
http://www.modified.com/news/0708_sc...hallenges.html
about 60% down the page, do a word search for yaris
Old 05-27-2009, 02:26 PM   #26
SailDesign
Drives: .
And you still haven't mentioned tire pressures - they are as important as susp. upgrades - really!
But that would be beating the dead horse again, so I'l shut up - none so deaf as those that won't listen....
(not you, Tamago, the OP)
Old 05-27-2009, 02:51 PM   #27
Tamago
Tamago's Avatar
Drives: UZJ100
add camber in the front
play with tire pressures.
install rear swaybar
get a little toe-out in the rear
should fix all your issues :)
tire pressures. play with them.
tire pressures?
Old 05-27-2009, 02:54 PM   #28
scape
scape's Avatar
perhaps he meant specific settings found useful?
Old 05-27-2009, 04:27 PM   #29
SailDesign
Drives: .
tire pressures?
One day he'll get it. But I expect to have at least one more post deleted by then. Not complaining, coz it wasn't a particularly nice post, but I really hope he gets it soon.....
Off-topic, is there a way to find out which mod deleted the post, so that I can ask which part of it offended? would make recurring offensive posts less likely.
Old 05-27-2009, 04:30 PM   #30
Tamago
Tamago's Avatar
Drives: UZJ100
more in the rear than the front ;)
where in S florida are you?
Old 05-28-2009, 08:08 AM   #31
scape
scape's Avatar
near fort lauderdale, but not for long-- planning on moving to south carolina for a temp position
Old 05-28-2009, 08:30 AM   #32
Tamago
Tamago's Avatar
Drives: UZJ100
ah! i'm downtown ft laud!
interested in hub spacers with free installation?
Old 05-28-2009, 08:50 AM   #33
regal
They have never lost grip, what else does a tire do?
Old 05-28-2009, 09:03 AM   #34
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
A grippier tire allows the car to enter the corner at a higher speed, maintain a higher cornering speed, and allows you to get onto the throttle sooner on the exit.
If your crap tires have never lost grip, then perhaps you aren't on the tire's limit yet.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 05-28-2009, 09:12 AM   #35
regal
Its not a tire issue, when I toss into a turn the whole car's momemtum flies foward pushing me into the steering wheel, Its like the entire body of the car is pushed foward like being rearended. With my other cars Civic, Jetta, BMW, etc you enter a turn pushed back firmly in your seat.
Old 05-28-2009, 09:24 AM   #36
SailDesign
Drives: .
That sounds simply as though you are hitting the brake instead of the throttle pedal. Is there another way you can describe this that might help us understand.
Also, you ask about what else a tire does other than grip. The sidewalls are very important, and tire pressures play into the eway they behave in cornering - hence all the beating of dead horses about tire pressures. A flimsy sidwall (like most OEM tires) will be lovely and comfy, but distort under cornering, allowing the tire to "scrub" and produce understeer. Higher pressures help with those, but stiffer sidewalls on better tires do more.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
