![]() Drives: 2008 Yaris RS 5-dr HB Black Join Date: Nov 2008
Steering Wheel Controls
Anyone know if there would be a problem with ordering a UK Yaris steering and putting it in my '08 Yaris RS? The Bluetooth and audio controls would be a nice feature. Thanks. :)
unless your head unit and wiring harness are identical, those features will not be available. in short, most likely a waste of $$
I was curious about that myself, but never checked into it because I changed to an aftermarket HU. I just pulled my 09's OEM HU off the shelf and powered it up on the bench. I tested the steering wheel control input (SW1, SW2, and SWG on the 20 pin connector).
Looking at the EWD for the European steering wheel controls, there is a switch and resistor network. The easiest functions to test were mode and Seek+. Mode is SW2 to SWG with no resistor and Seek+ is SW1 to SWG with no resistor. Jumping SW1 to SWG resulted in the frequency scanning upwards (i.e. Seek+). I stuck in a CD in and then jumped SW2 to SWG and it switched back to radio. So, the short answer is that at least the 09's HU (part number 86120-52A20) supports steering wheel radio controls. I don't believe that the bluetooth functionality would work, but at least the radio controls would. Besides the steering wheel, you'd also need the cable from the steering column to the radio (and possibly a new spiral cable that has the extra two wires in it). |
Thankz for your advice guys. I guess maybe I'll shift my focus back to heated mirrors. Cheers. :)
#5 | |
Sorry for the slight , but I figured this thread is toast anyways.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
If I still had my OEM HU in, I'd be adding switches to my USDM steering wheel right now. I am amazed that the radio really supports it.
The Gizmo Daemon would probably be fine. The easiest way to adapt it would probably be to hook up the SW1 and SW2 lines to the guts of a compatible joystick. Basically, one would connect in place of the potentiometer for each of the two axis. |
#7 | |
This may be in my future.
Yes. I didn't look through the source code, but the description mentions being able to scroll using a joystick. You may have to modify the code to look for specific "ranges" of the joystick and map them to a function, but it's definitely doable.
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
The steering wheel controls will work with aftermarket HUs if you get one of those steering wheel control adapters. Crutchfield and SonicElectronix carry a bunch of them. Some brands I can think of are PAC, Scosche, Metra, Peripheral and SoundGate.
#10 | |
Correct. Unfortunately my aftermarket HU doesn't support steering wheel controls. On my Xterra I modified the OEM steering wheel controls to work with the Sony HU I put in it (just had to change the resistor network). |
The head unit might support the use of steering wheel buttons ,
BUT does your clock spring , i was told no by the local toyota tech's but they know S##T. may be CTScott you have the answer too that as well , Please. |
The USDM ones definitely would need the spiral cable to be changed. The 07-08 ones only have the horn wire and the 09's have the horn and the cruise wires. The European ones with the steering wheel controls have the 3 additional wires.
Scion substitute?
Alright, I have been across the Internet and looking at the various galleries, can I take a stock Scion xD steering wheel (that has radio controls) and put a UK or Asian Airbag Steering Cover in place of the Scion Airbag Steering Cover? I really would like the steering wheel controls but wonder if any of you uber-techs would think this had a real chance?
I know I might have to get an aftermarket steering wheel control adapter but attached are some pics that might lend some insight. Sorry about pdf format but I am having trouble loading the bmp and jpg pics so they displayed. I defer to your wisdom.
#14 |
You are right on the money , they fit and fit perfactly .
the problem you have is the wiring from the steering wheel controls through the steering wheel clock spring , if these are not alredy to your clock spring then you will need too purchase the correct one , and that is not cheap. |
#15 |
There is a way around the new clock spring. If you are not doing the cruise control mod, using the OEM stalk, you can use the two wires that go through the clock spring for the steering wheel controls instead.
#16 |
So if it came from the dealer with cruise already in the stalk, will those two wires on the clock spring still be available to hook up to the steering wheel controls? And are two enough if the Scion xD steering wheel has 5 functions (Mode, vol up/down, + -)? Pardon my ignorance on the electronics side. Thanks to you both so far.
#17 | |
The buttons are multiplexed to work over a single pair of wires. |
#18 |
The cruise is on left so looks like we're in business. Thanks again.
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 02:41 PM |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 01:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 07:30 PM |
| Steering wheel audio controls? | vodkalush | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 09-14-2006 12:17 AM |
