![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
Bottoming out while heavy breaking/turning
I had gone over a curb, they replced everything from th oil pan to the xmember to the entire exhaust.
I'm on TRD springs, Tokico Blue hock, TRD reaer Sway. Under very fast heavy braking I sometimes feel something like the tranny bottoming out/grinding. Toyota dealer offered to look at it but they just usually baby drive. Do you thik I am just pushing the limits of the TRD springs? Its really not repeatable, only happens under the worst abuse, do you thik it is worth a trip back to the colllision center? |
rice rocket
Drives: 05 Echo Join Date: Feb 2007
time for a stiffer setup? :)
Time to stop abusing a Yaris??
what's your tire air pressure, and how much did you cut off your bump stops when you installed the suspension?
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
Or are you confusing the "sandpaper" feel of the ABS with something bottoming out.
But Yeah - tire pressures? |
Apexing Egg!!
try smoothing out your driving style, remember SMOOTH = FAST
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
Who said Yaris was slow?
answer my question please
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
not recommended... you'll be HATING life.. instant brake lockup
Break'em off some.
Break'em off some.
Tamago is right, you could be on the bump stops. My car never exibits this behavior and I am lower than you are.
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
Mine has no abs and the only time I lock up the brakes is when I'm being an idiot.
Another thing to check is the plastic inner-fender liner. I had a similar problem and it turns out I was rubbing on it (with stock wheels and tires) because it had popped in. I just pushed on it to pop it back into place. Mine was never in an accident or anything, I assume its from autocorssing. |
have you driven an abs equipped toyota with the relay removed? the brake booster is especially touchy on abs equipped models.
#17 | |
Apexing Egg!!
#18 | |
Break'em off some.
Yes if you start stabbing at the brake pedal, you are going to lock the wheels. |
| rubbing up front under heavy breaking | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 05-12-2009 12:23 PM |
| heavy braking | regal | General Yaris / Vitz Discussion | 8 | 05-12-2009 11:45 AM |
| ACT Clutch Kit 2007+ Toyota Yaris Heavy Duty 6 Puck | trini_per4mance | Items for Sale by private party | 0 | 12-20-2008 12:16 AM |
| A little Culture (heavy on the bandwidth) | GeneW | Off-topic / Other Cars / Everything else Discussions | 0 | 11-21-2008 04:50 AM |
| How Heavy is the flywheel? | jouslee | DIY / Maintenance / Service | 12 | 02-22-2007 02:18 PM |
