#325 |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
Hold on just a couple more days and I'll have that module installed. I just haven't had time to rip the dash again. I also have to rethink my clutch switch, the switch broke. That's what I get for going cheap :) Anyway, I'll prolly just buy the oem one. I'll put picks up when I'm done with all of this...
My Car Rules! |
#326 | |
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
but I understand an 09 has no need to rip apart the das? |
#327 |
![]() ![]() Drives: Red Yaris Join Date: May 2009
-Phil |
#328 | |
#329 |
![]() ![]() ![]() Drives: Yaris Join Date: Nov 2008
Well i pulled apart my dash on the 07 Australian Delivered Yaris, to find there is no CCS blue wire from the ECM to the AD4 Plug. Unless i got it wrong but there was a blue wire on the bottom row which i doubt was the CCS wire.. Very disappointing.
#330 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
You can run one very easily. It took me literally 20 minutes to install this from popping the hood all the way through to drive testing. And i had to run a wire.
#331 |
Ah yes. i saw on Page 16... will give it a shot tomorrow.
#332 |
boydstir
i have read most of this thread looks cool and cheap for cruise control . so on my early 08 lb automatic i can use the oem stock and what else do i need ? please help i put ton of miles on my car and cruise would be way nice to have for cheap
#333 |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
^ you need wires going from the ECM to the little hub in the steering wheel column, a wire going from that hub to a ground point, and the stalk, and then a jumper wire for two pins in the engine bay. Everything's been outlined and explained, so you just need to read carefully. That's about it. I'm selling my stalk btw, since I just don't really want it.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
#334 |
boydstir
cool thanks for the input
#335 |
![]() Drives: 09 LB, 3 door, auto Join Date: May 2009
So it should work ..
I have 09 3 door liftback, and it seems all I need is a stalk. Could someone give me a link to where you got the stalk ? Thanks a lot for the investigating this !
#336 |
#337 | |
http://cgi.ebay.com/ebaymotors/TOYOT...lenotsupported or TRDSparks.com ($81.99 plus shipping): part number: 84632-34011 |
#338 |
![]() Drives: yairs blue 2007 automatic 1.3 Join Date: Apr 2007
i am going to try this soon as i get bk home next month i have 07 yaris i just hope ull all b here to ask for my questions
#339 |
I don't think it will work on your car. On European manufactured Yaris cruise control is not an OEM option, so the ECM doesn't support this mod.
#340 |
![]() Drives: 5 door hatch Join Date: May 2009
Ok, after reading all these posts I am now REALLY confused so please bear with me since I am also new here. I have an '09 S 5 door liftback, auto trans. In real simple terms since I am not an electrical engineer, what do I have to do to have the factory cruise installed. The dealer wants over $500 for an aftermarket one which is ridiculous.
#341 | |
Or, check out this thread for adding cruise to your 09 auto for about $10: http://www.yarisworld.com/forums/sho...ght=diy+cruise |
#342 |
![]() ![]() Drives: 2008 Yaris HB Join Date: May 2009
Just to confirm after reading 24 pages.....this will work on an '08 MT but you need the stalk, the clutch switch and need to do some wiring to the fuse box, correct?
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 02:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 07:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
