Old 06-07-2009, 11:07 PM   #1
kngrsll
Apexing Egg!!
kngrsll's Avatar
Wheel weight Sticky?
Can we get a wheel weight sticky? Or incorperate that into another thread? I found the stock weights for my MR-S wheels and my new wheels:
Stock Toyota MR-S wheels: 15.2 lbs Front (15x6.5 +45) and 14.6 lbs Rear (15x6 +45)
Team Dynamics 15x7 +25 13.2 lbs Each
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-08-2009, 09:22 AM   #2
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
out of curiousity, does having wider rims upfront change the handling any?
Old 06-08-2009, 09:51 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
i ran the same wheels as ken on my corolla, and did not notice a difference, since i had the same size tires front and rear.
Old 06-08-2009, 09:54 AM   #4
kngrsll
Apexing Egg!!
kngrsll's Avatar
that probably depends on who you ask. If you want to get super technical, then yeah, it probably has a MINOR influence on how the car drives. In reality, it is probably so small, you cant detect it. The reason i have seen offset wheels on a FWD car was to run a WIDER front tire usually (like a 205 or 225 Front, and a 195 Rear tire; in fact the very first type R's ran this set up alot in Japan.) So you can do that, and make up for it in spring rate, damper settings, so on.
So why did i do? Because i am a cheap bastard. I got the wheels from a friend for free (i'm actually still "borrowing" them.) They are super light for stock wheels, and they look factory, like it is a Yaris-R model or something, and i like that.
The tire size is the same on the front and rear, and so the influence that wheel width has on handling is gone. So it will drive the exact same if i had the same size around or not. So basically, i am running two sizes for no other reason than that these wheels were free to me. You can't even tell by driving it, or looking at it. These are great wheels, i have thought about finding another set actually. I was going to use the wider ones for track tires (15x6.5), and the smaller ones (15x6) for street tires.
Old 06-08-2009, 09:55 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
keep an eye out for the 16's ! remember in 2003 toyota went to a 16X6.5 iirc for the rear
Old 06-08-2009, 09:59 AM   #6
kngrsll
Apexing Egg!!
kngrsll's Avatar
uh, what he said, in a few more words LOL
Old 06-08-2009, 09:59 AM   #7
kngrsll
Apexing Egg!!
kngrsll's Avatar
i think they would look really good for a street wheel. they weigh so little too!
Old 06-08-2009, 10:16 AM   #8
scape
scape's Avatar
i read that staggering the front to be wider is not a good idea regarding insurance and police- here in the states...too bad b/c it seems like a good idea
Old 06-08-2009, 10:35 AM   #9
kngrsll
Apexing Egg!!
kngrsll's Avatar
they would never notice. The tires are the same size, so you arent really staggering anymore.
Old 06-08-2009, 10:40 AM   #10
scape
scape's Avatar
i meant more of staggering the tires themselves, but your right the rims would be mostly unnoticeable
Old 06-08-2009, 10:52 AM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
staggering FTW!
Old 06-08-2009, 10:55 AM   #12
scape
scape's Avatar
ahh so it's common?
Old 06-08-2009, 10:59 AM   #13
kngrsll
Apexing Egg!!
kngrsll's Avatar
i dunno, those v-dub kids do crazy things
Old 06-08-2009, 11:03 AM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
that's a PURE autocross setup :D
285/30/18's front, 245/35/18's rear
Old 06-08-2009, 11:05 AM   #15
Morgan
Morgan's Avatar
Drives: 07 MM LB
2nd gen spyders have the 15/16 stagger
Old 06-08-2009, 11:07 AM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
ah, so 2002 :) my mistake
Old 06-08-2009, 11:08 AM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
on topic:
TR motorsports C1 15X8 +20, 13.5lbs
Old 06-08-2009, 11:11 AM   #18
Morgan
Morgan's Avatar
Drives: 07 MM LB
and for the record they do fit staggered on a yaris with 205/40
Weight Reductions scape General Yaris / Vitz Discussion 34 06-08-2009 02:31 PM
stock wheel weight? whiteghetto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 02-06-2009 08:00 PM
Wheel weight AlphaFox Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 09-04-2007 03:31 PM
weight on rs 15 inch wheel. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-04-2007 11:20 AM
