Old 06-10-2009, 04:29 PM   #1
bronsin
bronsin's Avatar
Notebook Without DVD Burner
Is there any way to load a modem driver into my new Acer notenook without a DVD burner? Thanks!
Old 06-10-2009, 04:38 PM   #2
Copy it onto a usb thumb drive.
Old 06-10-2009, 04:47 PM   #3
bronsin
bronsin's Avatar
Hmm I'll try it! Thanks! (will it let me copy it?)
Old 06-10-2009, 04:52 PM   #4
Yes. Just copy the folder(s) from the installation CD to the USB drive.
Old 06-10-2009, 05:38 PM   #5
bronsin
bronsin's Avatar
You know, while we're on the subject. Im getting a weak wifi signal (free wifi) with the notebook sitting on my desk at home. Is there anyway to improve the signal? If the wifi comes in I wouldnt need the modem at all.
Old 06-10-2009, 07:56 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Nope. Try moving your laptop to a different location in the house. See if that improves the signal. Where is the WiFi coming from? (you said it's free so I'm assuming you don't actually have wireless router or access point hardware of your own.)
Old 06-10-2009, 08:03 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
or buy a better USB wifi card
Old 06-10-2009, 09:06 PM   #8
bronsin
bronsin's Avatar
Oh man my head hurts. No...I dont have a router or anything. There are four wifi's identified when you startup. One of them doesnt need a password (Trend?) Wussa wifi card? I thought wifi reciever was built into the notebook? If I get this card will it help?How do you get at the wifi card settings? That must be in Windows? I guess the first thing is take it outside or upstairs. Thanks for all the help! Im new at this.
Old 06-10-2009, 09:23 PM   #9
bronsin
bronsin's Avatar
OK! Thank you very much! Im at work now but tomorrow at home I'll try that out and let you know what happens!
Old 06-11-2009, 06:43 AM   #10
bronsin
bronsin's Avatar
At ipconfig:
node: unknown
ip route enabled: no
WIN B proxy enabled: no
ethernet wireless network connection
media slate disconnected
description atheros ar5007egwireless net ad
apter physical address 00-23-2b-17-08-d9
control panel/device manager/properties/advanced
real tecrtl8102e
family psi-e-fastb
ethernet nic physical address 00-23-8b-40-25-2a
following proerties availible
802.11b preamble
map registers
mfp
network address
radio on off
Make any sense?
Old 06-11-2009, 11:20 AM   #11
bronsin
bronsin's Avatar
I was looking in hardware installed and found out the notebook has a "soft" modem in it. What is a soft modem? There is no phone jack on the outside for it.
Old 06-11-2009, 02:45 PM   #12
bronsin
bronsin's Avatar
make sure you select the proper adapter, i see you have a ethernet adapter and the wireless card. the wireless card is the atheros one so right click on it and go to properties advanced and look for all the settigns you should have one that says power save mode , make sure its disabled
I did shutoff the power saver. I get a useable signal sitting on the front porch. Thanks for the guided tour!
Old 06-11-2009, 06:03 PM   #13
bronsin
bronsin's Avatar
But minumum requirements require Cd/ROM.
Old 06-11-2009, 07:53 PM   #14
bronsin
bronsin's Avatar
Hmm thats what Im figgering out I have to do for the trendNet modem.
