Old 06-18-2009, 04:11 AM   #19
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
It's not fair, we don't get nothing good here in america...
Old 06-26-2009, 10:48 AM   #20
thekoket
Drives: Yaris 1.4 D4D
wow....it works perfectly for my yaris:X
thekoket is offline   Reply With Quote
Old 06-27-2009, 02:25 AM   #21
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Originally Posted by echo_hrs View Post
AFAIK all grades of Yaris in Canada are:
Power Assisted, Front Discs, Rear Drums, Antilock Braking System (ABS), Electronic Brake Force Distribution (EBD)...
My '07 doesn't have the ABS or EBD.
earljail is offline   Reply With Quote
Old 06-28-2009, 08:13 AM   #22
m5alfen
Drives: Yaris 1,8TS, BMW M3csl, BMW M5
Wow, thank you for a great tip. I pulled the relay for the VSC and TRC but that also killed the ABS. This was really great. I have a Yaris 1,8TS from late 2008.
Best regards
Alf Peter
m5alfen is offline   Reply With Quote
Old 09-28-2009, 06:03 PM   #23
StreetVibeTS
StreetVibeTS
Drives: yaris 1.8 ts
I have a South African model of the 1,8ts LB and it worked perfectly:). much more fun to drive..
StreetVibeTS is offline   Reply With Quote
Old 11-17-2009, 02:47 PM   #24
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
works on 2010 Yaris 5 door HB automatic
start car with foot on brake, let go of brake
within 30 seconds do this
hold handbrake, pump foot twice, let go handbrake
hold footbrake, pump handbrake twice, let go of footbrake
hold handbrake, pump foot twice, trac is now off
127.0.0.1 is offline   Reply With Quote
Old 09-06-2010, 11:14 AM   #25
Pingouin
Drives: Yaris
I bought a second hand 2008 T3 Yaris and do not know whether it has VSC or not. Is there any way to figure it out? I can see the ABS light for a moment when I start the engine, so I know I've got that!
I mean other then trying to smoke the tires and seeing if any lights come out :p
Pingouin is offline   Reply With Quote
Old 09-07-2010, 04:08 PM   #26
127.0.0.1
find some dirt large enough to drive in a tight circle, cut the wheel tight
mat the accelerator
if your car controls the speed and allows you to navigate that circle
you have traction control. if you make a partial circle then start to spin
out, or if the engine can rev way up and keep the wheels spinning, you
do not have it
Old 09-08-2010, 04:23 AM   #27
Pingouin
Drives: Yaris
Thanks for the tip localhost.
I was hoping that there would be some sort of more physical indicator, i.e. a light/switch/sensor that can be spotted. As I said, I don't get a "car skidding sideways" light when I switch on the engine, so my gut feeling is that I don't have VSC. Besides, it was an option, and on a 1.0 engine, I don't think the previous owner would have felt that he needed traction control!
Old 06-19-2011, 12:02 AM   #28
fase4
Drives: Yaris TS 05
I have a 2005 HB TS 1.5 and this not work for me... i only have a switch for TRC but not for VSC... some help?
fase4 is offline   Reply With Quote
