Old 10-16-2006, 06:45 PM   #1
DARKYARIS
Drives: 2007 Yaris RS HB
Disabled DRLs and Factory fog lights
For those of you who have disabled your DRLs and have factory fog lights, you will have noticed you no longer have use of your fog lights....or if you turn on your High beams AGAIN no fog lamps
The solution to this is find the small orange wire on the DRL harness and simply run it to a ground. Done now you can use at any time, headlights on/off etc
DARKYARIS is offline   Reply With Quote
Old 10-16-2006, 08:14 PM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
nice find.
will work for parts
vodkalush is offline   Reply With Quote
Old 10-16-2006, 08:25 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
If it's alright with you, id like to add this info to my How_To Disable DRL post. Didnt have fogs, so never knew this was an issue once they were disabled.
Old 10-16-2006, 11:06 PM   #4
DARKYARIS
Sure thing, what goes around comes around !
Old 10-17-2006, 03:16 AM   #5
xfatefailsx07
Lean Wit It. Rock Wit It.
xfatefailsx07's Avatar
Drives: 2007 Yaris Sedan - 5 Speed
teamwork baby teamwork
YARIS... enough said!
xfatefailsx07 is offline   Reply With Quote
Old 10-17-2006, 12:33 PM   #6
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
I dont understand why people want to disable their DRL, i mean i think its a pretty cool funtion to have.
Old 10-17-2006, 01:26 PM   #7
Devilsfan61388
Devilsfan61388's Avatar
Drives: 07 Yaris 2dr LB
Send a message via AIM to Devilsfan61388
^Yeah I agree, I like the DRL. But like everyone says it's thier personal preference.
Devilsfan61388 is offline   Reply With Quote
Old 10-17-2006, 07:05 PM   #8
Chris07LB
Chris07LB's Avatar
not everyone wants a 5" exhaust on their Yaris either... see where Im going with this?
"To Each His Own."
Old 10-17-2006, 10:12 PM   #9
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
Send a message via MSN to Teruyume
Do u mean grounding the orange wire on the DRL relay connector?
06 Yaris RS 2Dr HB 5MT Orange
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Kumho Ecsta AST 195/50R15
Tanabe DF210
JDM LED Tail lights
Teruyume is offline   Reply With Quote
Old 10-17-2006, 11:47 PM   #10
hasher22
Look mum no stars!!
hasher22's Avatar
"To Each His Own."
Though i didnt say anything about a 5" exhaust in da 1st place
Old 10-18-2006, 04:30 AM   #11
Chris07LB
Chris07LB's Avatar
Sorry 4".
Old 10-18-2006, 12:04 PM   #12
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Where was the thread about hooking up the DRL circuit to fog lights so the fogs could be used as DRLs?
Did anyone figure that out?
I'd like to hook the DRL circuit up to the parking lamps once I get my HID kit, but I'm at a loss.
Help?
Old 10-18-2006, 05:12 PM   #13
Black Yaris
der Zeck
Black Yaris's Avatar
I just disabled my DRL... love it, when I had them the Lights were so bright they bounced off my garage door and I could not see to back out my driveway when it is dark.... now all I need is some LED markers to make my headlamps shine blue :)
Old 10-18-2006, 07:23 PM   #14
Chris07LB
Chris07LB's Avatar
Like these?
Keep in mind, all eight 8' lights were on inside the garage when I took this. At night, they light up the headlight housing.
Old 10-23-2006, 05:15 AM   #15
window_lee
Drives: Yaris RS 2007
Can anyone show me so pic how to connect the orange wire to the ground
window_lee is offline   Reply With Quote
Old 10-28-2006, 12:05 AM   #16
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
yeah, have the factory fog light, but it only can be on when the low beam is turned on. Kinda useless. Would like to know how to reconnect the wire so I can have the fog light on whenever I want! A step by step walk through would be appreciated. Thank you!
GabL is offline   Reply With Quote
Old 10-30-2006, 12:54 AM   #17
DARKYARIS
OK....this is to easy. I don't think it really requires pics.
On the (Harness) side , where the (DRL) plugs in. Take a look at the connector(Harness) Locate the orange wire, push a wire into the connector at this point, then hook up to a grounding point.
Old 10-31-2006, 09:59 PM   #18
GabL
I want JDM bumpers!
GabL's Avatar
Sorry, it might sound easy to you, but I have no clue what you're talking about.
Here is what I understand:
1. Locate the harness, should be under the steering wheel where the DRL module is.
2. Locate an orange wire
3. Push a wire into the connector (This I'm having problem with, where I get the wire from? And push the wire to where in the connector??)
4. Ground it (Agin, ground what? And how?)
It might sound stupid but a detail walk through will be much appreciated. Thank you.
