Old 06-22-2009, 04:13 PM   #343
Originally Posted by Henry G. View Post
Just to confirm after reading 24 pages.....this will work on an '08 MT but you need the stalk, the clutch switch and need to do some wiring to the fuse box, correct?
Correct. We really need to do a DIY for 07-08's...
Old 06-22-2009, 06:14 PM   #344
Henry G.
Drives: 2008 Yaris HB
That would be AWESOME. Thanks for all the info so far guys, great job.
Henry G. is offline   Reply With Quote
Old 06-22-2009, 06:20 PM   #345
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I have a 08 mt lb and a stock, lets do it.
POORSHA is offline   Reply With Quote
Old 06-22-2009, 10:36 PM   #346
For your MT you're going to need the clutch switch as well. It's OK to bypass it for testing, but for normal use you really should have it in place.
Anyone else from the New England region interested in doing theirs? We could do a DIY cruise control workshop.
Old 06-23-2009, 01:02 AM   #347
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
I may move the led I have mounted next to the switches up into the guage cluster before I install the LED module CTScott has provided. Make it look a little more stock-ish. Also scott, if my LED is too bright I can just add a resistor of my choice in series and that'll dim it down some correct? And also I'm going to just buy the stock clutch switch for 20$ from the dealer, rather than try to fix the frankenstein I put together :)
My Car Rules!
nickhjort is offline   Reply With Quote
Old 06-23-2009, 10:26 AM   #348
Yes, you can add a resistor to dim it. If you used a blue LED, you might have to go up to between 30K and 50K Ohms for it to not be blinding.
Old 06-23-2009, 04:33 PM   #349
POORSHA
POORSHA's Avatar
Drives: 2008 LB
A workshop would be great.
Old 06-23-2009, 09:54 PM   #350
Bravejus
Drives: 08 Yaris 3 door 5MT
I would like a workshop as well, or a well written DIY on the whole process with lots of pictures. The information on how to do this is rather scattered over 24 pages, especially if you have an 07-08 5mt.
Bravejus is offline   Reply With Quote
Old 06-23-2009, 10:10 PM   #351
Well, we're up to two for the workshop. Would you be willing to drive down to Connecticut for it?
Old 06-24-2009, 02:52 AM   #352
nickhjort
nickhjort's Avatar
I am also willing to help out if people want to drive to Oneida, NY. I see that Bravejus is just up in Plattsburgh.
My Car Rules!
Old 06-24-2009, 06:19 AM   #353
Bravejus
Well it would depend on schedules meshing for sure. Oneida is 3.5-4 hour drive.
Old 06-24-2009, 01:48 PM   #354
nickhjort
nickhjort's Avatar
Well I'm always free on weekends, so let me know what you think
My Car Rules!
Old 06-24-2009, 06:03 PM   #355
POORSHA
POORSHA's Avatar
Drives: 2008 LB
any sunday
Old 06-24-2009, 08:10 PM   #356
Bravejus
So I have an 08 LB 5mt. What will I need to make the cruise work. I want to go the homemade switch version. Do I need a certain voltage switch? The radio shack across the street has illuminated switches for 2.99 each. What resistors.
So I have to run a wire from the # 40 pin on the ecm to said switches correct? What about grounding etc.
I really want to have cruise this weekend. I have to start commuting 105 miles each way for work.
Old 06-24-2009, 10:07 PM   #357
Henry G.
Brave I have an '08 LB MT too I would go the stalk method...you really need to know WTF you are doing to go the switch route, and there will be a lot of work involved. CTScott makes it sound easier than it is I'm sure, I run the electric grid for a living and am JUST following along with his LED and resistors method.
Old 06-24-2009, 10:17 PM   #358
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Im going the stalk switch route, however doing the wiring myself, like nickhjort, just need to find the time
Old 06-24-2009, 10:20 PM   #359
AlexNet0
AlexNet0's Avatar
when I finally get around to doing it, I will make one, however it will be the stalk method, since I like more of an oem look.
Old 06-24-2009, 11:52 PM   #360
If you use illuminated switches, you will need to power the lights from a separate isolated circuit (such as the interior illumination circuit).
Take a look at my DIY Cruise Control Thread for the switch and resistor info:
http://www.yarisworld.com/forums/sho...ght=diy+cruise
Basically, any normally open, momentary switch will be fine. The switches are switching 12VDC at negligible current.
For an 07-08:
In the Steps mentioning Connector D3, the blue (CCS) and brown (ECC) wires are replaced with a wire from the red wire of the switches to CCS on the ECM (pin #40) and a wire from the black wire of the switches to a ground point (a bolt connecting a ring terminal to the bare metal of the dash support structure for example).
For MT on 07-08:
The clutch switch (Toyota part number: 88280-14030) is required. A wire is run from each of the two terminals of the switch to the terminals of the under hood fuse panel connector shown in nickhjort's picture below (either switch terminal to either connector terminal is fine).
http://i236.photobucket.com/albums/f...t/CIMG6560.jpg
The 07-08 will not have a cruise control on indicator unless something like the module I developed is used. You can not simply use an illuminated switch, as the on/off switch is a momentary switch, which toggles the function on or off.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 02:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
