Old 06-30-2009, 11:34 AM   #1
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Camshafts?
Ok, so I do not quite get this from everyone who i use to keep hearing that cams won't bring any new power?
The NA car in Siphon had new cams which made power so why not our 1nz-fe?
Has this engine ever been flowtested? or has someone just had a simple regrind of what they thought would work and it didn't?
I never saw anyones proof on this matter, especially for our turbo brethren wanting more? GARM!!!!!
But seriously, wheres the proof on this?
Old 06-30-2009, 12:32 PM   #2
06silveryaris
Drives: 2006 yaris
cams make power regrinds or not, a aggresive lift and duration set up will help a turbo or n/a engine. I have to see any for the yaris here in pr but i am sure people are doing regrind because there are a few turbo echos and yaris around and going fast.
06silveryaris is offline   Reply With Quote
Old 06-30-2009, 12:37 PM   #3
06silveryaris
Drives: 2006 yaris
it seems this guy is using factory cams I thought he had aftermarket after doing some research he claims it is a stock motor. Besides the turbo ect
http://www.youtube.com/watch?v=Edx3D42A3Wg
Old 06-30-2009, 12:44 PM   #4
Nexus1155
Drives: Audi
thanks for posting up, yeah i am sure there is something to be had, even with a stock head. The link didn't work by the way
Old 06-30-2009, 12:49 PM   #5
06silveryaris
Drives: 2006 yaris
try it now
Old 06-30-2009, 12:50 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
any more specs on the build?
Old 06-30-2009, 12:52 PM   #7
06silveryaris
Drives: 2006 yaris
not really I can look into it, but later i have to go back to work
Old 06-30-2009, 03:30 PM   #8
clappitty
Drives: Yaris Hatch 09
shot them an E-Mail. thanks for the link Cali
Glad I joined up on YW today.
Still need to read up on the few turbo builds.
clappitty is offline   Reply With Quote
Old 06-30-2009, 05:11 PM   #9
cdydjded
Drives: Yaris LB Turbo
No one here has changed their cams in there Yaris, so you are getting opinions from people with no experiance on the matter
Are you speaking of the one from Japan?
Engines do not get flow tested, cylinder heads do
Go here o learn about regrinding: http://www.autofieldguide.com/articles/099804.html
cdydjded is offline   Reply With Quote
Old 06-30-2009, 10:39 PM   #10
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Wonder how expensive those head packages are
Old 06-30-2009, 11:10 PM   #11
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
around 1500-1700 depending on your core returns/shipping distance , I've looked into it...
Old 07-01-2009, 02:47 AM   #12
Nexus1155
Drives: Audi
Honestly, I'm not sure of the specs on the stock cam. But I do have the specs on the regrind from Gude. If I had to guess, the only real change is probably duration. I don't understand how they could get more lift out of a stock cam. Not if all they are doing is taking material off. My understanding is that on a regrind you can change the lobe profile in order to have longer or shorter duration as well as a more or less aggressive opening of the valves.
Anyway, here are the specs on the Gude Cams...
Part Number: SCXBS01
Intake Cam: Lift - 0.420, Duration - 238
Exhaust Cam: Lift - 0.400. Duration - 238
According to the Gude website they include racing springs and shims, the power band is from 3500 - 8000 rpm and the idle is "good."
And as long as we are talking about Gude, they also sell a ported stock throttle body.
Part Number: N/A
Max Dia. @ Taper: 53.3mm
Dia. @ Butterfly: 47.0mm
Heres the dyno from the gude worked on engine with a very rich afr, if you lean it out you should be making more power
295 intake/285 exhaust cam was the specs from the siphon car..
Who has an extra $400+ cash for mods and doesn't mind a week downtime and wants to try this!!
So to get good NA power out of this we are saying, cam regrind, and raise compression, and 1zz throttle body? to keep everything low cost. because I think i remember someone who was working over the head said the head wasn't really restricted to begin with and is well crafted..
Old 07-01-2009, 09:46 AM   #13
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
I know a guy who has been doing cam grinds for years and years. if you guys are very interested in them i can inquire. but just to let you know that the power you'll get verus the price you pay won't be worth it. Usually factory cams work well on a turbo'd car. I don't ever plan on changing mine...
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 07-01-2009, 11:21 AM   #14
+1. We tried twice to do the cams on my tC and it lost power both times. Rado's Time Attack car has stock cams in it. I know that's a 2.4L but it serves as evidence.
Old 07-01-2009, 11:30 AM   #15
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
the guy from california who works for junction produce(don't know username) supposedly has the GUDE package on his car......
Old 07-01-2009, 12:12 PM   #16
turboecho2005
i sent an email out to an old friend who does cams. he actually got back to me in 15 minutes! which is amazing cause its canada day. I gave him specs on the stock duration and lift and valve angle. he said he'll do some research and see what he can do. If its doable he'd need a cylinder head with stock cams for exact measurements.
Old 07-01-2009, 01:08 PM   #17
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Agreed.
Just out of curiosity, does anyone have the specs on the stock cams for the 1NZ-FE?
Old 07-01-2009, 01:46 PM   #18
^ see the post before yours, apparently turboecho has the specs.
Post them up, turboecho
Performance Camshafts acer1958 Performance Modifications 2 11-09-2012 06:09 AM
