Old 04-29-2009, 11:11 PM   #1
jmew0ng
Drives: Scion FRS
Got engine check light :(
P0304 is the code that says misfire...
So I'm going to try and swap out the spark plug, but which one is cylinder 4?
on the very left?
jmew0ng is offline   Reply With Quote
Old 04-29-2009, 11:13 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
how many miles, and what mods? if you need a new coilpack i have them
Originally Posted by xnamerxx
you nailed it sir.
Old 04-30-2009, 12:10 AM   #3
jmew0ng
Drives: Scion FRS
40k AEM Intake..
I don't need to change all 4 do I? D:
Old 04-30-2009, 12:44 AM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
clear the code, see if it comes back. do that before you spend any $$
you nailed it sir.
Old 04-30-2009, 01:13 AM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Mine was tripping misfire codes at high RPM last time I was at Sebring. Replaced all four plugs with good ol' NGK V-Power plugs and never looked back.
Old 04-30-2009, 02:40 AM   #6
YarisSedan
Drives: 08 Yaris Sedan
List what mods you have. If you have a missfire and your car is running okay at the moment is intermitent and could be a high rpm miss like loren says. You only need to worry if the car starts running rough and you have a blinking check engine light. Meaning its missfiring bad enough to damage the cat and possibly 02 sensors.
I would try clearning the code first. And see what happens. The number 1 cylinder is closest to the cam and crank i belive and 4 is furthest away. either way just swap the far left and far right. Then clear code. If it says cylinder 1 is missfiring now then you know you have a coil problem.
If it still says cylinder 4 missfire then you ahve either a spark plug problem, fuel problem, or mechanical problem such as low compression.
If you hav ebeen consistantly running a low quality IE non toptier gas. (toptiergas.com) I would suggest running fuel system cleaner and removing plugs and spraying them down with carb cleaner to remove all the carbon buildup.
Old 04-30-2009, 03:33 AM   #7
jmew0ng
Drives: Scion FRS
ah i'll go give that a shot....
do I just reset ECU to clear code?
and if so, which fuse do I pull again :<
Old 04-30-2009, 04:05 AM   #8
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
what do the plugs look like? if you swap the plugs and the misfire shows up on #4, if you have a digial camera, take a pic. I am curious to see what the gap is like and the condition of your spark plugs.
P.S. on most cars, pulling the nagative battery terminal off for a few minutes or more will reset the computer...no point in resetting it tho for the first test...if the spark plugs to blame you will get a #4 misfire when you swap the plugs around...and you will just have to reset the computer again.
Old 05-08-2009, 04:24 AM   #9
jmew0ng
Drives: Scion FRS
it's been a few days and light hasn't came back on...
does it mean it just slipped up once or something?
Old 05-08-2009, 12:30 PM   #10
severous01
pulling the bat is a bad idea for resetting ecu. the thing has to re-learn your driving habits and fuel economy programming n stuff...you can get a cheap handheld scanner for less than 20 bux now at autozone that will give only code numbers and ability to erase codes......
or, if you're seriously a cheapass you can go to autozone and talk them into deleting codes...they're not suposed to but they will with a little convincing
Old 07-01-2009, 07:27 AM   #11
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
ok guys..my light has came on...
i currently have a weapon r dragon sri and recently installed an lpx performance muffler.
ive had the intake for a while now...no problems.
i've had the muffler installed 2 weeks now...any idea why it went on?
i m at 16k is it that time to bring her in for service? i would just hate to bring her in if its something that could be done by deleting the code....
msfire671 is offline   Reply With Quote
Old 07-01-2009, 08:36 AM   #12
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Read the post directly above yours. If you can afford a performance muffler, you can afford a code reader. You need to know what the code is when the CEL comes on. And the code reader will clear codes.
Old 07-01-2009, 09:42 AM   #13
msfire671
msfire671's Avatar
thanks mr. pimpin yaris =] my brother has one and he'll check it tomorrow...crossing fingers that it's nothing serious... =/
Old 07-01-2009, 12:10 PM   #14
YarisSedan
really just take it to the dealer this is a warrenty item
Old 07-01-2009, 10:16 PM   #15
msfire671
msfire671's Avatar
well see i would take it to the dealer...but theres only one toyota dealer here on guam and if i do turn it in to them they might need it the whole day...and this is my only daily driver...but if the code comes out to be a bad thing..then yes i without choice i will take it to the dealer... =[
thanks for the replies! =]
Old 07-01-2009, 11:09 PM   #16
Yaris Hilton
Smile
Having a brother with a code reader's a good thing.
Check engine light on kcty DIY / Maintenance / Service 19 03-10-2012 09:54 PM
check engine light twice within a week of purchase?? conurebuddy General Yaris / Vitz Discussion 8 04-17-2009 11:53 AM
Check engine light AGAIN! Grandieri General Yaris / Vitz Discussion 7 04-13-2009 08:38 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 02:43 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 06:15 PM
