Old 07-06-2009, 04:43 AM   #37
jkuchta
Drives: 2007 Yaris hatch (red)
Originally Posted by suprf1y View Post
OK, so it looks like its a bucket style lifter, no rocker.
Hydraulic, or solid lifters?
I'm pretty sure they're solid shim-over-bucket lifters, with the exhaust cam timing being fixed and the intake cam timing being variable.
jkuchta is offline   Reply With Quote
Old 07-06-2009, 04:57 AM   #38
you might find more information in here:
http://www.yarisworld.com/forums/att...4&d=1137530385
Old 07-06-2009, 05:09 AM   #39
after reading that PDF again, they are shimless buckets, i.e. to adjust valve lift, you swap for thicker buckets from Toyota...
Old 07-06-2009, 11:02 AM   #40
suprf1y
suprf1y's Avatar
Drives: 05 Echo
Well that pretty much makes it difficult, and unaffordable.
If I had to weld the cores, then grind them to maintain your stock lifter setup, that would make it too expensive.
Sorry guys.
suprf1y is offline   Reply With Quote
Old 07-06-2009, 12:53 PM   #41
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
Thanks for trying mike!
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 07-06-2009, 01:09 PM   #42
let's keep the discussion open, this is super informative for me, and probably for others.
If Mike is willing?
So when someone like GUDE sells cams for our cars, what exactly did they make then?
Old 07-06-2009, 01:18 PM   #43
kngrsll
Apexing Egg!!
kngrsll's Avatar
i would love a set of NA cam regrinds
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 07-06-2009, 01:47 PM   #44
Doesn't post #41 indicate that you can't do a simple regrind? .. I'm a bit over my head on the technical part of this.
Old 07-06-2009, 02:55 PM   #45
jkuchta
Sorry guys.
I'm pretty sure the buckets aren't that expensive.
Wouldn't it be possible to offset grind the cams on their base circles and then use thicker buckets to take up the slack, thereby giving you more lift without running into coil bind?
Old 07-06-2009, 04:05 PM   #46
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I don't think you want more lift. With VVTi you might end up hitting the piston.
You have four valves already. Wouldn't better intake and exhaust manifolds with porting give more reliable results?
Old 07-06-2009, 06:32 PM   #47
jkuchta
It could, though higher lift/more duration would also make for better results with an intake and exhaust. Somone will have to measure the "worst case" valve clearance of this motor to be able to tell how crazy you can get on the 1NZ without the valves beating all of the pretty off the pistons, though with lower compression (hint Garm), there'd be even more room for lift, as the piston is either going to be flycut or dished to drop the compression, which would yield more lift potential.
Old 07-06-2009, 07:25 PM   #48
CDavis7M
Drives: 1990 Supra Turbo
I believe that the 1NZ-FE motor is a non-interference design. So, hitting the pistons should not be an issue.
It might be possible to ditch vvti to help with tuning, however, that is a whole other issue. And having an exhaust cam alone might not be worth the hassle.
CDavis7M is offline   Reply With Quote
Old 07-06-2009, 07:34 PM   #49
Tamago
Tamago's Avatar
Drives: UZJ100
the 1nz an interference engine.
ditching the VVTI is by far the worst thing you could do to the 1nz
Old 07-07-2009, 01:29 AM   #50
CDavis7M
My mistake. Now I see the reference to the valves hitting the pistons in the Service Manual.
Old 07-07-2009, 09:53 AM   #51
suprf1y
suprf1y's Avatar
Drives: 05 Echo
By all means, see what thicknesses are available, and price them out.
I'll keep an eye on the thread.
Like I said, if I think we can do something, I'm game.
Not sure what you mean by offset grinding the cores.
Old 07-19-2009, 12:11 PM   #52
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
this is an exciting thread! ;d hope to see more dev in this area
Performance Camshafts acer1958 Performance Modifications 2 11-09-2012 06:09 AM
