Old 05-05-2009, 03:21 PM   #19
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Does anybody know if the Scion Xd stalk will work? I am curious as to whether or not it cross-reference with any of these p/n's and also, might it be LESS expensive?
DerFlosser is offline   Reply With Quote
Old 05-05-2009, 08:55 PM   #20
DerFlosser
DerFlosser's Avatar
Drives: Yaris
FYI...here is the intermittent stalk found on the 2008 Xd.
Old 07-07-2009, 10:33 AM   #21
luigi
luigi's Avatar
Drives: '07 Sedan
Two months later...
What a fantastic mod. Now for those of us without rear wipers...are there any switches to suit us?
I guess I could just install a rear wiper; that would be fun.
luigi is offline   Reply With Quote
Old 07-07-2009, 10:38 AM   #22
Originally Posted by luigi View Post
Two months later...
Or, just ignore the rear switch. Everything else will work fine.
Old 07-07-2009, 10:43 AM   #23
the stalk from an 09+ matrix/vibe also works....took apart a friend of mine's 09 XRS to try it on my yaris....works fine, but just the intermittent fronts....not the intermittent rear, its still on/off only
Old 07-07-2009, 10:53 AM   #24
The intermittent rear requires a module and an extra wire, which the Yaris doesn't have. I picked up the module from a Prius, but it needs feedback from the rear wiper motor, which the Yaris's wiper motor doesn't provide.
I built my own module which includes a potentiometer to allow for fully adjustable rear intermittent. I use timing, to replace the feedback signal on mine. I haven't had a chance to package it and install it on my car yet, but on the bench it works perfectly. I will probably mount the knob for adjusting the intermittent delay to the steering column, by the stalk.
Old 07-07-2009, 12:08 PM   #25
luigi
luigi's Avatar
Drives: '07 Sedan
Sure, but what about the aesthetics? Thanks for the info, CTScott.
Old 07-07-2009, 02:13 PM   #26
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Is there a work around for the stalk using a dash mount switch. just like the $ 10.00 cruise?
POORSHA is offline   Reply With Quote
Old 07-07-2009, 02:23 PM   #27
Hmmmm... Actually, the circuit for the intermittent front wipers is built into the stalk, so a work-around is definitely possible, but would require a circuit like my rear intermittent one. Then, you would have a dash or column mounted knob to adjust the delay. It wouldn't require a switch, as the standard stalk has an intermittent mode.
Old 07-08-2009, 05:37 PM   #28
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Hmmm
Old 08-21-2010, 04:25 AM   #29
Wildcat
Wildcat's Avatar
Drives: '07 Yaris Hatchback
Great writeup CTScott!
The stock wiper switch has bugged me from day one. I also ordered the part from autoworksinc.com. The guy was very helpful and I got the part the very next day.
The dealership wanted $208 for the stalk. No thanks. The guy at autoworksinc pulled mine from an 07 Prius as well. $50 + shipping.
The whole upgrade took about 7 - 8 minutes max and works like a charm.
Wildcat is offline   Reply With Quote
Old 08-21-2010, 02:10 PM   #30
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
I had to do this mod on my focus, same procedure excpet the part was only 12 bucks.
mr9865 is offline   Reply With Quote
Old 08-25-2010, 02:53 AM   #31
birdman
Drives: '08 Blazing Blue Yaris LB
Is there a generic multi speed switch that could be spliced into the rear wiper wiring for multi speed intermittent wiping? Oh by the way the Scion XD switch is a match.
birdman is offline   Reply With Quote
Old 08-25-2010, 09:07 AM   #32
The simplest off the shelf solution would be an adjustable time delay relay like this:
http://www.newark.com/jsp/search/pro...FC-GB100000001
Old 08-25-2010, 05:29 PM   #33
Revsson
Hey, did you steal my part from Wisconsin??
I'd love to do the fog light stalk, but not sure I want to pull the steering
wheel. I realize this one can be done without doing that.
Old 08-26-2010, 03:23 PM   #34
Wildcat
Wildcat's Avatar
He said he's pulled a few wiper stalks off of Prius' lately.
Old 09-01-2010, 08:14 PM   #35
Chrsto4
Chrsto4's Avatar
Drives: 2008 Yaris RS 5-dr HB Black
Definitely a mod on my radar. Thanks CTScott for the quick fix.
___________________________________________
Chrsto4.
Mods: Tinted Windows, Clifford Remote Starter, GPS, Driver's Side Grab Handle, Parrot RK8200 (Sweet)
Chrsto4 is offline   Reply With Quote
Old 09-04-2010, 07:50 PM   #36
Pingouin
Drives: Yaris
Nice, I defo wanna do that. I did it on my previous car (a Ford Focus), but it cost me £15 back then, which was well affordable and worth it. But $50 to $150 is a no-no for me :(
Pingouin is offline   Reply With Quote
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 04:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 08:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 11:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 11:57 PM
