Old 07-07-2009, 06:31 PM   #19
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
not complicated...install the shims the same time you're installing the rear hub spacers...
Old 07-07-2009, 06:37 PM   #20
kimona
kimona's Avatar
Drives: 2014 White VITZ
Marcus, skip the camber adjustment. You're wasting your bloody time and effort.
Old 07-07-2009, 06:39 PM   #21
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
why do you have such a problem with camber in the rear?
Originally Posted by xnamerxx
you nailed it sir.
Old 07-07-2009, 06:45 PM   #22
Penguin Garage
Penguin Garage's Avatar
Drives: Yaris
you got it, just slide the washers int at the same time.
no extra effort. :)
Penguin Garage is offline   Reply With Quote
Old 07-07-2009, 06:47 PM   #23
kngrsll
Apexing Egg!!
kngrsll's Avatar
When my car was completely stock, i did an alignment. Set the toe to zero in the front and pulled in as much camber as i could. In the rear i pulled most (but not all) of the toe out of the rear and added about a degree of rear camber.
The car drove and handled much better.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 07-07-2009, 06:49 PM   #24
kimona
kimona's Avatar
Camber has it's place, but in this case just isn't necessary and no realized advantage on the Yaris with the particular set-up Marcus is going for here on his daily driver.
If you want to track the car, then that's a different story altogether.
Old 07-07-2009, 07:03 PM   #25
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
ok ok ...no camber kit then..lets keep this as is..i just thought since i maybe getting the spacer might as well add shim or washer on it to slightly tilt the rear wheels. thats all..
Old 07-07-2009, 07:33 PM   #26
Penguin Garage
Drives: Yaris
when you get the hub spacers you'll have everything needed if you want to add a little extra negative camber.
Old 07-07-2009, 08:10 PM   #27
marcus
toyota
marcus's Avatar
right on!! ill be contacting you mr penguin as soon as i get the new shoes.
