![]() Drives: Yaris 5door D4D Join Date: Jan 2009
Help. Instability on highway
Hello from Spain.
I´ve a '08 Yaris D4D with 6x16" rims (from a Corolla TS) and 195-50-16 tyres (Toyo Proxes T1R). Stock suspension. The problem is that in highway driving over 60millas, the car is very hard to keep straight. It affects the state of the road, wind and even the air to the advancement of other cars. It is very uncomfortable. Do you think that putting Eibach springs with stock shocks will be better? What alignment should be better for highway? Thanks very much!! PD: this is my car ![]()
now in HD
assuming you're still on stock/oem suspension, a straight oem-spec alignment is best for the highway. make sure to get well within specs for toe especially.
a bad tire+wheel balance would contribute less to your problems, but i'd check that too.
Yes, I have oem suspension.
The weight of my 16" are the same of the oem in 15". The car is only 25.000kms (about 15K miles) Thanks! |
now in HD
yes. start with the alignment first. it's relatively inexpensive considering it affects so many variables, including tire wear.
TRD rear sway bar. End of story.
I don't think there is anything wrong with your Yaris that we haven't all experienced at highway speeds.
Beast
Drop the car, add a bar, it helps lots
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
the TRD rear bar helped my car's stability very much on the highway- with everything else stock
Yes, I think that TRD sway bar will help me. Tomorrow will pay a new one from ebay... :D
Thanks!!! |
#10 | |
check your tire pressures. virtually free.
also, if you DO opt for an alignment, have the tech err on the side of toe-in up front (while still maintaining factory specs) if you want the car to handle better at higher speeds.
I was running 38psi in front and 36 rear. (in other cars usually have this tyre pressures and all ok)
Few weeks ago, I put 29psi rear and front and the car goes a little better. Thanks very much! |
www.yarisclub.gr
Drives: yaris 1.3 2sz - 1.33 1nr Join Date: Jan 2009
put 32psi and the springs.
#14 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
My thought exactly.
It makes a world of difference (huge stability and handling improvement).
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#15 |
Hello guys!
Finally, I bought an Ultra Racing Rear Sway Bar (19mm) and a set of rear hub spacers (10mm) When I install them, I told you the results :D Thanks!! |
| highway speeds and noise | gaf99 | General Yaris / Vitz Discussion | 26 | 04-19-2012 11:36 PM |
| Considering Yaris vs. Elantra | businezguy | New YARIS Purchase Forum | 69 | 06-21-2009 08:39 AM |
| Highway driving | SuperYaris123 | New YARIS Purchase Forum | 15 | 05-08-2009 01:22 AM |
| Take the long way home on the highway or short trip home through city? | tinymilad | General Yaris / Vitz Discussion | 10 | 12-27-2008 12:23 PM |
