Old 07-13-2009, 10:25 PM   #145
Originally Posted by Blue_dragon_192 View Post
ctscott,
one last question (for the next 30 seconds )
With the 07=08 mod, all we are doing to shorting pin 40 on the ECU to ground to turn on the CS and then short it to ground with a load (~600 ohms) to set the CS..
Or did I miss something?
Blue
That's all that's to it. See if your sedan has a wire already in pin 40. If so, you can tap it way up under the dash (per the discussion buried in that thread), or at least tap it somewhere along the line.
Old 07-13-2009, 10:35 PM   #146
Blue_dragon_192
Drives: 2009 Yaris 4dr Sedan
Ok. The next dumb question. Where is the ECM??????
Blue_dragon_192 is offline   Reply With Quote
Old 07-13-2009, 10:42 PM   #147
PatrickJohnson
Drives: 2008 Yaris LB
if you are standing in front of the car looking at the engine bay, it is attached to the firewall in the upper left corner
PatrickJohnson is offline   Reply With Quote
Old 07-13-2009, 10:43 PM   #148
And to answer the next question, here's the location of pin 40:
Old 07-13-2009, 10:56 PM   #149
Blue_dragon_192
OK.
looking at the engine bay and now understand the diagrams....
Since it's too dark out and my wife's scion is in the garage, I will attempt this at a different date.
Thank you all for your input...i hope this works.
Old 07-14-2009, 02:06 AM   #150
Revsson
Where's the engine bay??
just kidding
I have the factory cruise, but if I didn't, I'd probably try this mod.
CT Scott is one of the best with electronics in this forum!!!
Old 07-14-2009, 08:52 AM   #151
Blue_dragon_192
just kidding
Wait................These things have engines?
And here I thought they ran by magic.
Revsson, I am very fluent in sarcasm.......
From all the posts I read, CT Scott knows his stuff. I now have to get the courage to mess with the ECM and get the cruise working.
I am far more comfortable in a room full of servers, the car stuff is a little daunting, when dealing with an ECM!
Old 07-20-2009, 11:57 AM   #152
bronsin
bronsin's Avatar
I had the Yaris out this weekend for a trip to upstate NY and back. (about 250 miles each way) So the CC mod got a good workout. It worked very well indeed! The car got just about 40 mpg when I set the speed on 70 mph. I did the four switch version which gives you plus one and minus one mph at the touch of a button. It came in very handy and I recommend going the four switch route if you install this mod. Getting the Radio Shack really mini switches made doing the four switch really easy...
Old 07-20-2009, 07:43 PM   #153
TylerJ
Drives: Blazing Blue 2007 3dr HB 5MT
Unhappy Help with cruise control switches
I have been looking for a cruise control solution for a while, I am glad I found this thread
I have a 2007 Yaris 3dr Liftback with 5 spd MT, if I can't see the lit icons that you showed in the first few pictures does that mean I can't perform this DIY?
TylerJ is offline   Reply With Quote
Old 07-20-2009, 08:28 PM   #154
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
It just means no indicator lights - the actual cruise will work fine, if properly connected.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 07-21-2009, 09:15 AM   #155
You can do it on a USDM 07 for sure. You will need to run a wire from the switches directly to the ECM's pin 40 on an 07 or 08. Also, with a MT you will need to add the clutch switch and wire it to the connector in the under hood fuse panel. Check out the tail end of this thread for more details:
http://www.yarisworld.com/forums/showthread.php?t=16188
Old 07-21-2009, 04:50 PM   #156
tforkner
Drives: 08 liftback 5 speed
Here's how I did my clutch switch. I used a SPDT submini roller lever switch, Radio Shack # 275-0017. I superglued it in place on the metal bracket.
tforkner is offline   Reply With Quote
Old 07-22-2009, 12:00 PM   #157
TylerJ
Thanks for those of you who responded to my question. I am thinking about doing this mod this weekend. I will update on how it turns out.
Old 07-22-2009, 12:40 PM   #158
bronsin
bronsin's Avatar
Does anyone know the Toyota Part Number for the dash panel next to the ignition switch? (the one I put the switches in for the CC) Im thinking it would be handy to have in case the car needs warranty work!
Old 07-22-2009, 06:00 PM   #159
55446-52060-B0
Old 07-22-2009, 08:48 PM   #160
bronsin
bronsin's Avatar
Thanks much appreciated!
Old 07-23-2009, 03:19 PM   #161
bronsin
bronsin's Avatar
55446-52060-BO is $22 BTW.
Old 07-25-2009, 03:16 PM   #162
TylerJ
I have two SPST N.O. momentary switches from radio shack and a pack of resistors I was just wondering what combination to use ... I have seen some people use 630 and others 660, I can do either with the supplies I have but was not sure about which is better CTScott mentioned I will have to hardwire the clutch switch into my under hood fuse box ... is this because we dont have the connector near the clutch pedal to just plug it in?
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 01:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 07:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 02:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 11:16 AM
