#55 | |
![]() ![]() Drives: 08' HB Join Date: Oct 2008
0 - 60 in 3 shifts
#56 |
do you need me to post the dyno flow charts? the twin screw makes its power sooner than your centrifugal. which is important for a car that only revs to 6500rpm..
and either way, turbo>lysholm/centrifugal GLWS
#57 |
post away. What are people pulling on a dynojet with the Blitz 117-120? @ 8 psi whoa!
You could always start your own informational thread if you wanted too.
0 - 60 in 3 shifts
#58 |
well mine made 133whp on my first pull; then i had to stop because of my AFR was lean. However, I have larger injectors now, along with a 1zz throttle body. I'm sure it'll get higher numbers next time.
how's that pending sale going? |
#59 |
Were your 1ZZ injectors light blue with 12 holes? Yeah could say your car was running lean i saw your dyno, you should dyno it again soon to see if it's better instead of just assuming.
And good thanks for asking.
0 - 60 in 3 shifts
#60 |
That's what my wideband is for? Thanks for looking out for me!
#61 |
your wideband can verify hp awesome!
0 - 60 in 3 shifts
#62 |
#63 |
Your right that is what it sounds like I meant when I read it now too. I should have used a period.
On that note though, I brought a set of 1zz injectors to check out, they were light blue with 12 holes and flowed the same as our stock light blue 12 hole ones. I was sad because I hoped they would flow more. Mine came from a Celica? I actually at one time posted the flow rates of oem Toyota injectors one this forum too
0 - 60 in 3 shifts
#64 |
I bought them used from ebay. I'm not sure how many holes they had. However, my numbers on my wideband dropped by one point once the 1zz injectors were installed. Went from 12.5 at WOT open loop, to now 11.3-4 at WOT open loop.
#65 |
Did this thing ever sell? Bump it.
#66 |
"Stealth Runner"
also curious
#67 |
I think someone did buy it.
#68 | |
#69 |
yep, thread closing in 3...2....1...
| What Kind Of Super Charger | Kaotic Lazagna | Off-topic / Other Cars / Everything else Discussions | 3 | 06-08-2009 04:28 PM |
| Power Enterprise Super Charger Kit Round 2 $3100 | Power Enterprise Evan | Forced Induction Forum | 312 | 03-26-2009 06:48 PM |
| Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? | ceboyd | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-08-2006 02:13 PM |
