Old 07-24-2009, 12:06 PM   #19
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Sorry I was refering to some of the systems the have the nozzle in the end of the come filter. not much option to put it behind the MAF then. Like this one.
http://www.compperformancegroupstore...rAirAmplifiers
Old 07-24-2009, 12:10 PM   #20
saplaymate
saplaymate's Avatar
Drives: 08' HB
Originally Posted by 2bad4u View Post
Step 5: Install Nitrous Nozzle
Optimum nozzle placement is 6” to 18” from the throttle body. This range of distance gives the nitrous
and air proper time to mix before entering the intake manifold plenum. Remember, nitrous nozzles
must always be mounted after the mass airflow sensor, never before them. After you have determined
where to mount the nitrous nozzle
Lilredrocket this is from the installation manual on Zex site it states "nitrous nozzles must always be mounted after the mass airflow sensor, never before them"
That's for a wet set-up
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 07-24-2009, 12:12 PM   #21
2bad4u
Drives: 06 Toyota Vitz RS
I like this set up much better
2bad4u is offline   Reply With Quote
Old 07-24-2009, 12:34 PM   #22
Tamago
Tamago's Avatar
Drives: UZJ100
i ran a 35 wet shot on the xA before i went on boost. it was fun.. but as previously stated, a wideband o2 should be on your list of things to buy before you get spray happy. i'm contemplating a dry 75 shot on the xA right now, since i have my FIC and large injectors already installed.
Old 07-24-2009, 12:40 PM   #23
lilredrocket
Slowy getting there
Drives: 08 Liftback
Are you going to frankinstine the kit like your turbo kit? (not saying its a bad thing.) I'm really thing about doing a 30 dry shot like the OP. I have started saving links for a turbo kit too!!
Old 07-24-2009, 12:41 PM   #24
Tamago
Tamago's Avatar
Drives: UZJ100
what do you mean frankenstein?
like "not buying the components from the same manufacturer"?
i already have a bottle that fits nicely under the airbag cover so i'll probably use it again.
Old 07-24-2009, 12:52 PM   #25
lilredrocket
Slowy getting there
Drives: 08 Liftback
Exactly. Like for the turbo set up I would like to buy the HKS but I think I'll be able to piece one together for cheaper
Old 07-24-2009, 01:57 PM   #26
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
what happened to that turbo sponsorship?
Old 07-27-2009, 12:36 AM   #27
2004javablack
Drives: Lift Back
i have a cold air intake, light wheight crank pulley, that is about in 4 performance mods.
2004javablack is offline   Reply With Quote
Old 07-27-2009, 12:37 AM   #28
2004javablack
Drives: Lift Back
and a axel back exhaust.
teaser pics from japanese trip :) enviri Off-topic / Other Cars / Everything else Discussions 29 04-07-2009 02:33 AM
TRD spring install pics tristan Photo-Video-Media Gallery 10 02-20-2009 10:33 PM
Deals Gap pics HTM Yaris Photo-Video-Media Gallery 3 05-15-2007 06:02 PM
Turbo Kit Teaser Pics cdydjded Performance Modifications 27 01-31-2007 12:58 AM
