Old 11-11-2006, 10:30 AM   #91
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
Originally Posted by eco
Hey itsmydaily,everything fits fine with the Tanabe strut bar installed,just make sure they dont toch,i got some sparks,but thats because I installed the kit after the bar,alot harder.I only have the alternator and the intake hooled up at the moment,I also have my voltage stabalizer installed,I deffinitly notice the car is smoother,and when I start the car,it starts quicker,and the starter sounds stronger.
thankx, thats good to know. looks like I'll be getting the strut bar then
Got any pics? I'm curious to see where you mounted the voltage stabilizer.
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 11-11-2006, 11:44 AM   #92
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Ok,Ill take some pics today.But if your curious and cant wait,I mouted it between my battery and fuse box.
eco is offline   Reply With Quote
Old 11-11-2006, 10:28 PM   #93
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
My curiosity on this grounding kit
http://cgi.ebay.com.au/New-JDM-Groun...QQcmdZViewItem
hmmmmm should i? its just looooooksss soooo pretttyyyy......
Old 11-11-2006, 11:18 PM   #94
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
For $85....I'd pass.
the_saint is offline   Reply With Quote
Old 11-11-2006, 11:51 PM   #95
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
wow never seen one like that before, good find, but not worth the price.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 11-12-2006, 12:01 AM   #96
eco
eco's Avatar
It looks like that stabilizes voltage aswell,but I think youll have a very hard time mounting that,you may,but you will not be able to see that voltage meter.Ill post the pictures of my partial install tomorrow morning.
Old 11-12-2006, 11:02 AM   #97
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
You ground what u wanna ground.
Yes but do I need more grounding points?
Old 11-12-2006, 11:57 AM   #98
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
You don't need to have more. six is enough and even five would be enough. Only put more if you want to add more grounding points. Otherwise six is plenty.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 11-12-2006, 03:54 PM   #99
hasher22
Look mum no stars!!
hasher22's Avatar
I believe there are 6 main points to ground. Though from what i heard/seen u can have 13 grounding points......correct me if im wrong...
Old 11-12-2006, 06:35 PM   #100
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Well here are the results from my grounding kit:
W/O GROUNDING KIT
---------------------OHMS----VOLTS
Alternator----------- 0.6-------0.02
ECU-------------------1.7-------0.005
Throttle Body------- 1.2-------0.011
Transmission-------- 0.6-------0.016
Head------------------0.7-------0.016
WITH GROUNDING KIT
---------------------OHMS-----VOLTS
Alternator------------0.6--------0.011
ECU-------------------0.6--------0.008
Throttle Body-------0.3--------0.001
Transmission--------0.1--------0.009
Head------------------0.5--------0.009
The Ohms were read while the engine was off, volts while engine was on. The readings were taken using a Fluke 87 Ohmmeter. The leads were placed, red on the bolt being tested, black on the negative terminal on the battery. The volts were a good indicator of how the resistance was reduced, since the more voltage flowing through the grounding wire, the less voltage drop across the voltmeter. If you wish, I can tell you exactly which bolts I used for my hookups/readings.
I will tell you this, I can detect a small difference in the pull of my engine at higher speeds. It feels a little more willing at higher RPMs. Nothing major though. Idle doesn't really feel any smoother. I'll let you know about any MPG changes, if there are any.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 11-12-2006, 11:32 PM   #101
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
i think we need a new thread
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 11-13-2006, 07:39 AM   #102
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
I agree.
Has anybody bought a grounding kit yet and not installed it? Also are you willing to take pics?
will work for parts
vodkalush is offline   Reply With Quote
Old 11-13-2006, 10:45 AM   #103
nsmitchell
nsmitchell's Avatar
I can take pics of my installation, so the locations will be clearer.
Get YarAss in gear!
RIP - Casey Tatum
Old 11-13-2006, 10:57 AM   #104
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
nsmitchell interesting results. I think I will get some reading on my points over the coming weekend. I'd like to see what you decided to ground with your install.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 11-13-2006, 01:10 PM   #105
eco
eco's Avatar
Sorry,Ive been busy,Ill try to post pics tonight.
Old 11-13-2006, 01:48 PM   #106
vodkalush
I drive a yarrrris
vodkalush's Avatar
Well I feel like a special ed student...
if anyones wondering on how to install a Bought Grounding Kit then go back to the first page and to post 1 of this thread....
I think what still needs to be made is the DIY Guide for making and installing your own homegrown grounding kit.
will work for parts
Old 11-13-2006, 02:15 PM   #107
Katana
Katana's Avatar
Thanks, you saved me 30 euros.
Guys is anyone interested in a DIY Grounding Kit for the 1.3lt engine?If yes I can fix you up!
Old 11-13-2006, 03:52 PM   #108
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Has anyone measured the length of the wires in the e-bay kit?
The average person can't make a kit for $22 when you factor in the cost of quality wire at $1 + per foot and quality ring connectores at $1 a piece or more.
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Bluetooth Kit Info so40 In Car Entertainment + Electronics (audio / video / alarm) 13 07-12-2009 05:13 PM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
