Old 07-21-2009, 03:31 AM   #1
Pattycake
Drives: Yaris
Send a message via AIM to Pattycake
Arm rest problem!!
I have a stock 07' Yaris Sedan. My arm rest doesn't stay down..as you can see in the 1st pic.. its opened and it always pops back up when i push it down. The problem is the hook on the top part doesn't grab the bottom part because the top part is pushed out and it stays like that like a mechanical umbrella that wont stay closed all the way. the 2nd pic, you can see the arm rest has a little gap.. thats what i need to somehow push back in and make it stay.. the 3rd pic is how the gap is supposed to look like..nice and tight. with a teeny gap. so the hook for the top part of the arm rest can grab the bottom. can anyone please help me with this situation? thanks!!!
Pattycake is offline   Reply With Quote
Old 07-21-2009, 11:04 AM   #2
Revsson
I suppose I shouldn't comment, as I don't have an armrest, but I would think that there
is a hinge back under there. Perhaps you could check to see if there are screws that
hold the hinge on and make sure they are tight?
Old 07-21-2009, 12:54 PM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Show us a picture of the hinge and latch. There maybe some adjustments you can make.
Old 08-02-2009, 11:02 PM   #4
Pattycake
Drives: Yaris
Here's the picture. Hope this is any help... ;/
Old 08-03-2009, 01:02 AM   #5
yaris-me
Learn to Relax
Whatever is loose is not exposed. Look behind the armrest to see if there are screws you can tighten. If it is broken plastic, it will be a harder fix.
Old 08-03-2009, 10:44 PM   #6
Pattycake
Drives: Yaris
ahh.. alright thanks for your help though!
Old 08-03-2009, 10:48 PM   #7
Keith Tinari
Scrubble with a poke.
Keith Tinari's Avatar
Drives: 2009 Yaris LB
The plastic latch is just worn out. Go to a local dealer and pick one up. Should be very cheap. More than likely under 10 dollars. Well worth the aesthetics to fix it.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen
Keith Tinari is offline   Reply With Quote
Old 08-03-2009, 11:09 PM   #8
supmet
Drives: 2007 4 Door Yaris
There are 2 screws(maybe 4) in the cupholder behind the console lid. Remove those, and then pull the big piece of plastic on the back off. That should leave you with the above picture. Tighten the four screws in the top of the picture, and the four on the bottom of the lid at the bottom your picture
I had this exact problem, and this fixed it perfectly.
Here's how to assemble it:
And these are the four screws you need to tighten:
Old 08-03-2009, 11:42 PM   #9
Pattycake
Drives: Yaris
Thanks a lot man! I'll be sure to try that out.
Old 08-13-2009, 04:15 AM   #10
Pattycake
Drives: Yaris
WHOO thanks man it works!!!
FS: Lift Back Arm Rest kenkyd Items for Sale by private party 5 04-09-2009 01:21 AM
Anybody installed the factory 2 door hatch arm rest? firebird1999us DIY / Maintenance / Service 4 02-09-2009 03:52 PM
Center Arm Rest Rotorheader Items for Sale by private party 12 09-27-2007 05:25 PM
Arm Rest Big1Dave General Yaris / Vitz Discussion 10 09-12-2007 12:40 PM
Arm rest review Chaad32 General Yaris / Vitz Discussion 36 09-19-2006 07:42 PM
