Old 11-11-2006, 03:30 PM   #1
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
bought some redline mt-90 to put in my yaris' tranny
i'll change it by tomorrow and will post results. i've ran this stuff in my corolla and it helps out a lot when the weather is cold.
tekmoe is offline   Reply With Quote
Old 11-12-2006, 03:44 PM   #2
OK Yaris
Drives: 2007 Liftback
So, how many quarts did you use?
I've used Redline in other cars/trucks. Good stuff.
OK Yaris is offline   Reply With Quote
Old 11-13-2006, 09:56 PM   #3
tekmoe
ex-yaris owner
i drained the crap that was in there after i got it real hot. i actually let it drain for almost 45 minutes because i had to go to walmart with a friend during that time. when i got back i filled the tranny up with the redline and used two 1-quart bottles. i spilt a small amount while pouring and then after i was done i pulled the tube out of the filler hole and a small amount started dribbling out of the filler hole. that didn't seem right so i screwed the filler plug back in to stop it from leaking. i don't remember this happening with my corolla and it also uses 2 quarts.
regardless, i've put close to 70 miles on the car so far with the redline mt-90 and it feels pretty much the same with the exception of my tranny will last MUCH longer than running that stock crap. i guess having a brand new tranny won't show much of a difference when switched to synthetic unless its cold outside.
Old 11-14-2006, 02:49 AM   #4
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
I might do the same thing,I might get mine flushed first.
eco is offline   Reply With Quote
Test drove Fit, Versa and Yaris... Bought a Yaris! AlexK General Yaris / Vitz Discussion 49 09-10-2007 05:35 PM
Just bought my yaris! cblu07 New YARIS Purchase Forum 8 09-12-2006 04:36 PM
