Old 08-07-2009, 11:14 PM   #91
OK. I just probed mine - I see 3.94 volts on each of the SIG lines with the seat empty, ~4.00 volts with me sitting on the seat (and I weigh about 155 lbs), and ~4.20 volts when I put all of my weight on the corner being measured.
Based on that we should flip your 10K and 470 ohm resistors to make the passenger airbag active. To make it inactive, we are probably looking at increasing the 470 ohm to about 2.5K to 3K.
When you have a chance, measure the voltage of one of your connectors from pin 2 to pin 3 for me. Also measure Pin 1 to Pin 3.
Old 08-07-2009, 11:39 PM   #92
MGargano
Drives: 2009 Yaris Hatchback
Ok, so I should run 10k from 1-2 and 470 from 2-3? That should keep the passenger's airbag active all the time?
Old 08-07-2009, 11:41 PM   #93
MGargano
Oops... I meant I should change it to 470 from 1-2 and 10k from 2-3, right? I currently have it set with 10k from 1-2 and 470 from 2-3
Old 08-07-2009, 11:46 PM   #94
Correct 10K 2-3 and 470 1-2 for airbag always active.
Old 08-07-2009, 11:53 PM   #95
MGargano
Ok, I'll try to do this tomorrow before work and let you know. If all goes well, the passenger's airbag light should say 'on' and the passenger's seat belt light will turn off when belted, right?
Old 08-07-2009, 11:55 PM   #96
I believe so.
Old 08-08-2009, 12:00 AM   #97
MGargano
Fingers crossed!
Old 08-08-2009, 12:24 AM   #98
MGargano
How's this look?
I couldn't wait until tomorrow or Sunday
Old 08-08-2009, 12:24 AM   #99
MGargano
Old 08-08-2009, 12:25 AM   #100
MGargano
Old 08-08-2009, 12:46 AM   #101
MGargano
No change in any of the indicators after swapping these, but maybe it's because of the missing/wrong resistors in the airbag sensors?
Old 08-08-2009, 08:01 AM   #102
Did you by any chance measure the voltage between 2 and 3 and 1 and 3?
Old 08-08-2009, 08:27 AM   #103
MGargano
I'm sure I have the required tools for this, but how would I go about doing this?
Old 08-08-2009, 12:02 PM   #104
this is a really good read. Guys when it's all done, can it be compressed and posted as a DIY? I know a lot of people who would like to know how to do this!
Old 08-08-2009, 01:04 PM   #105
jonismyname
Drives: 08 liftback 5spd
you guys are no joke. if co-workers and married couples could co-operate as well in the same room as you guys are over a forum the world would be a very different place... rock on.
jonismyname is offline   Reply With Quote
Old 08-08-2009, 07:55 PM   #106
We'll definitely turn this into a DIY once we figure it all out.
As far as clearing the current stored codes, Let's try a couple minute battery disconnect. The SRS system supposedly clears most types of stored codes if it is off for a while. If that doesn't work, we can manually clear them via that same jumper we used to make it flash the light patterns. The process for clearing them that way is a bit convoluted, so hopefully the power down will do the trick.
Old 08-08-2009, 09:14 PM   #107
MGargano
I'm guessing I should wait until I install the correct 3 ohm resistors in the SRS senors before disconnecting the battery? Otherwise we'll still have the same problem right?
Old 08-08-2009, 09:18 PM   #108
You could try it as-is to see if we clear the code 32 and have the passenger air bag on light.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
