| View Poll Results: Which HID kit would you be more intereste in? | |||
| HID with halogen high beam for about $80 |
6 | 9.52% |
| HID with true high/low beam for about $20 more |
57 | 90.48% |
| Voters: 63. You may not vote on this poll | |||
#19 |
would these have a glare shield that allows using with the reflector optic housing?
#20 |
kioshi, not sure what you mean, but if we were talking by PM, that's a losing battle for me - sorry!
ezhacker, dunno what you mean, these go anywhere an H4 bulb goes?
#21 |
![]() ![]() Drives: stock Join Date: Apr 2009
i think for me will get another set HID....
as my old car i have use 55w ballast with 55w hid bulb ...the output light is very far... like a beam of line.... |
#22 |
Garm,
Would the use of this HID kit allow me to retain my DRL module (for fog lights) while, at the same time, allow the high beam indicator to work in the dash panel? My biggest hang-up so far in purchasing an HID kit is one that will allow me to retain stock features such as the two thing mentioned |
#23 | |
Heart Up! Vitz
#24 |
^ mmm, gold pieces?
![]() derflosser, an HID kit just plugs in line where the headlight bulb goes. As far as I know (I'm not an electrical guru), this should have no effect at all on any other function (as long as it gives low and high beams). I'm sure someone else can answer this better than I can.
#25 | |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#26 |
Yeah...that is what I was referring to. Does the Halogen Hi-Beam and xenon low beam configuration by Xenon-Vision retain the high Beam indicator in the dash? The only negative to this configuration that I know of is that the light cutoff is not as good as with the bi-xenon.
#27 |
Heart Up! Vitz
#28 | |||
![]() ![]() ![]() Drives: '07 Yaris Sedan/'03 Protege Join Date: Oct 2008
the same way the stock bulb would. One connection to control each bulb. If it's wired correctly there should be no difference from stock. However, some Bi-Xenon kits use a single bulb which moves from low to high position and it's possible that you could lose the high-beam indicator, depending on the wiring configuration. Quote:
#29 |
are these projectors or reflectors? because of how light scatters badly on non-modified hid bulbs in the oem headlight housing.
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
| KLight HID Conversion Group Buy!! $165.00 shipped!! | JRT lighting | Sponsors Classifieds Area | 4 | 11-20-2006 10:47 PM |
