Old 08-08-2009, 10:44 PM   #127
MGargano
Drives: 2009 Yaris Hatchback
OK. Check the ECU-B fuse under the hood.
Fuse is intact
Old 08-08-2009, 10:46 PM   #128
MGargano
Is it possible to resume this tomorrow? My car's in the driveway and it's starting to rain. Plus it's getting kinda late. I have all day tomorrow, if you're game and available?
Old 08-08-2009, 10:52 PM   #129
No problem.
Old 08-09-2009, 09:16 AM   #130
The first thing to check, when you have a chance today is a couple of voltage readings on the Occupant Classification ECU cable harness.
If you look at the image above J24 has the Black connector going to it and U1 has the Gray connector.
Pull the J24 Black connector and then measure the following (on the cable connector side):
Put the black lead on pin 3 and the red one on the wire being checked.
Pin 1 (Violet wire) to Pin 3 (White wire with black stripe)
Pin 7 (Beige wire) to Pin 3 (White wire with black stripe)
Old 08-09-2009, 10:05 AM   #131
MGargano
Pin 1-3: looks like .14
Pin 3-7: looks like .12/.13
Old 08-09-2009, 10:18 AM   #132
MGargano
And, of course, as soon as I get outside, it starts pouring rain. I'd continue, but I have to keep getting out of the car so I can move closer to my house where my iPod Touch can pickup an internet signal to keep refreshing the forum for directions
Old 08-09-2009, 10:47 AM   #133
Nothing like working in the rain.
Are those readings with the ignition on or off?
It should be on for the readings. 7-3 should be 12V with the key on or off. 1-3 should be 12V only with the key on.
Also, with your meter, when I had you check the meter by measuring the battery voltage last night, did you see 14., as opposed to the .14 that you just read on 1-3?
Old 08-09-2009, 12:03 PM   #134
MGargano
Ok it's all good now. Your diagram's pin numbers didn't match up with my connector but I was able to figure it out based on the colors. I have 12V all around now.
My connector seems to be labeled left to right, whereas as yours is right to left
Old 08-09-2009, 12:05 PM   #135
MGargano
Scratch that...I'm retarded. Your pic is of the ECU, not the connector. It's all good now.
Old 08-09-2009, 02:21 PM   #136
That gets confusing. Sometimes the pics are of the cable side, sometimes of the device side.
OK. So both power feeds into the module are fine. Try removing the resistors and then reading the 1-3 and 2-3 voltages on the sensor connectors.
Old 08-09-2009, 02:26 PM   #137
I am totally subscribed to this. Mgargano and CTScott, BIG props to both of you for having this conversation on a thread.
Old 08-09-2009, 02:32 PM   #138
MGargano
Which pins get which leads?
Old 08-09-2009, 02:34 PM   #139
black on 3, red on 1 then 2
Old 08-09-2009, 02:44 PM   #140
MGargano
Ignition on, J24 plugged back into the OC-ECU, resistors on the 4 weights sensors removed and....
Nothing. Zeros on all four sensors for 1-3 and 2-3
Old 08-09-2009, 02:50 PM   #141
And, U1 (the gray connector) is plugged in?
Old 08-09-2009, 02:56 PM   #142
MGargano
Yes
Old 08-09-2009, 03:01 PM   #143
OK. Try measuring each of the three pins relative to chassis ground (a seat mounting bolt would be fine). Red on 1, 2, and then 3 and black to the bolt.
Old 08-09-2009, 03:09 PM   #144
MGargano
Still nothing...all zeros
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
