Old 08-11-2009, 04:36 PM   #19
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
yah??
Old 08-13-2009, 12:43 PM   #20
marcus
toyota
marcus's Avatar
still getting the shimmy on 60-65mph ..slight vibration on the steering wheel..could it be due to me going to 16x7 and wider tires as well..vs stock.. can our yaris get a 4 wheel allignment..i know some cannot be done on the rear..
Old 08-13-2009, 04:47 PM   #21
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
What exactly have you done so far to fix the problem?
(hint: start by having the tires rebalanced)
Old 08-13-2009, 05:08 PM   #22
marcus
toyota
marcus's Avatar
pumped the tire on an even psi for all four..but before that it was rebalanced all four.. but i was told to jsut drive it for a while "break in" so im still waiting to hit atleast 500 kms.. steering vibration is not that bad but id rather not have it..the rear end does looked like its more slanted than stock. angled in i guess due to wider tires..
Old 08-13-2009, 06:12 PM   #23
Loren
What?
Loren's Avatar
Your alignment has nothing to do with the vibration. (I said that once already, but it bears repeating)
Your new tires have affected your alignment in no way.
Tire vibration issues are not cured by "breaking in" the tires.
If the shop that mounted your tires isn't capable of properly balancing your tires (not that uncommon, really), find one that is.
Sports car folks swear by the Hunter GSP9700, you might find a shop that has one. Of course, even the best equipment (this goes for wheel balancing as well as alignment) is only as good as the tech that's using it.
The GSP9700 is a "road force" balancer. It doesn't just "spin up" the wheel, it has a roller that simulates the force of the road and does a much better job of balancing the tire.
In my experience, a good tech that gives a shit about what he's doing and approaches the job with a goal of "perfect balance using the least possible weights" instead of "just slap weights on where the machine says to and if the blinking light says it's okay, even if it's .25 oz off, send it out the door" can get the job done with even low-tech equipment. Sometimes breaking the bead on the tire and rotating it 90 degrees to adjust for imperfections in the wheel and tire can help these problems... most techs aren't willing to do it, even when it's the right thing to do.
Old 08-13-2009, 06:40 PM   #24
marcus
toyota
marcus's Avatar
ok i got local tire place that had the GSP9700 machine.. $80.00 cnd to balance all four though..yikes i dont mindpaying that assuming that they can fix the issue..
Old 08-20-2009, 03:48 PM   #25
marcus
toyota
marcus's Avatar
UPDATE!! rebalance by gsp9700.. got better but still that slight vibration on the steering wheel unless ive always had it...the previous balance weight did come off again so hope this stays and the minimal vibration aint too bad to deal with wel shall see..
Old 08-21-2009, 02:59 AM   #26
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
hey buddy , i had a similar problem a while back.
the solution was that one of the spicot rings that go inside the rim when going on the hub was missing , and the other one was the incorrect one making that the wheel wasnt on properly. check the spicot rings , the usually little round plastic rings , make sure they work with that specific wheel , and that they fit in flush , if not , then that is your prob.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 08-21-2009, 10:47 AM   #27
Loren
What?
Loren's Avatar
A cheap plastic centering ring that's not a proper fit or wasn't installed properly and interfered with fitment can be a problem. Otherwise, with lug-centric wheels (acorn style lug nuts) centering rings are completely unnecessary and it doesn't matter if they are there or not. I've run many different aftermarket wheels on many different cars without them and never had a problem with balance or anything else on the street or the track.
The centering rings make it easier to put the wheel on the car and serve no other engineering purpose. The lug nuts actually center the wheel. I've seen an engineer's analysis of this. There are two arguments for hub centering rings on lug-centric wheels: centering and load-bearing.
1. Modern wheels are machined with the lug holes cut to the same centering tolerances as the center bore, this is not an issue.
2. The centerbore is not relevant to supporting the weight of the car. The car is supported by the friction between the wheel and the hub that results from the clamping force of the lug nut torque. Interesting and surprisingly understandable "back of the envelope" calculations attached. (Derived by Lance Schall, as posted to Miata.net a long time ago in a galaxy far, far away.)
Old 08-21-2009, 01:09 PM   #28
marcus
toyota
marcus's Avatar
wow its like high school all over again..
Old 08-23-2009, 12:41 AM   #29
Loren
What?
Loren's Avatar
Well, yeah... except this is IMPORTANT stuff!
Old 08-23-2009, 09:41 AM   #30
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Thanks Loren. After listening to way too many opinions I was starting to doubt myself on the whole Hubcentric thing. Thanks for the sanity check.
soloecho2 is offline   Reply With Quote
Old 08-23-2009, 01:03 PM   #31
YarisSedan
Drives: 08 Yaris Sedan
Your missing hub centric rings. So the wheel is not centered on the hub. Its equivelent to having a bent rim. Its going to get worse and eventually your wheel will fall off. I used to work at a tire shop we would get them all the time. We would do a tire rotion and then customer would complain of horrible vibration. Because the wheel would be slightly off center. We would get 2 people one person hold the wheel as centered as possible on the hub while someone else quickly zips them down. Its never going to be perefect centered without the ring but it would be better.
Old 08-24-2009, 10:45 AM   #32
marcus
toyota
marcus's Avatar
all rings are intact and proper sizes..
Old 10-01-2012, 07:36 PM   #33
henrystyle
Drives: 2010 5 door yaris
I know this thread is old but I am having the same exact problem. Going to have all 4 tires high speed balanced in the morning.. We shall see if that solves the problem. I have stock rims with new stock size tires. Hopefully the problem goes away..
henrystyle is offline   Reply With Quote
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 07:30 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
