Engine Immobilizer p/n
Anyone have the Engine Immobilizer p/n('s) that you would need in order to add this feature to your Yaris?
Amplifier, Transponder Key: 89783-71021
Computer Assy, Transponder Key: 89780-52061 |
The ECM is the same with or without the immobilizer system. I believe that it's just those two parts and the wiring between them and the three wires to the ECM.
It sounds like the wires might already be included in the factory harness and you could just plug in the two parts and not have to run any wires to the ECU???
![]() I'll check into the 09 Sedan wiring diagram section for the alarm and see if this information is included. |
Just check your steering column to see if there is a black 7 pin connector sitting near the key switch and not connected. It will have 4 wires - pink, green, purple and gray.
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
| After-the-fact engine immobilizer? | Echostatic | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 08-01-2007 10:03 AM |
