Old 08-19-2009, 10:04 PM   #55
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
no, Im talking adding fuel to the nitrous. Wet is spraying nitrous mixed with fuel, dry is nitrous only
Old 08-19-2009, 10:04 PM   #56
ChinoCharles
Drives: LB
I believe that is incorrect lilredrocket. Direct port is done through the fuel injector (basically). Wet kits are individual ports on the intake manifold runners, and dry kits are done anywhere pre-manifold.
Old 08-19-2009, 10:06 PM   #57
AlexNet0
AlexNet0's Avatar
A wet single-point nitrous system introduces the fuel and nitrous together
wiki
Im sorry I should have been more specific.
Old 08-19-2009, 10:18 PM   #58
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Well i could go dry, but i wouldnt even dare push a 50 dry shot threw this engine since we have no tuning out for us...Also with a Wet im alittle worried about the stock Mani puddling and me getting a good'ol backfire. We'll see how it goes once install rolls around. This will be my 7th nitrous setup ive installed.
Old 08-19-2009, 10:28 PM   #59
AlexNet0
AlexNet0's Avatar
yeah, Im going 35-40 tops wet "single shot", through an injection spacer between throttle body and intake mani. at least untill I have the cash for internals.
Old 08-26-2009, 03:39 AM   #60
AlanSRT4
Drives: SRT4
Originally Posted by changchewsoon View Post
sorry to bring up an old thread, i just want to share this with everyone.
this is a dyno chart of a stock yaris automatic transmission equipped with a wet nitrous kit running a 50 shot fogger nozzle. timing was retarded when the nitrous starts spraying.
engagement of the nitrous is done via e-manage, using the vtec output.
the owner later increased it to a 75 shot and spun a rod. it is now going through a rebuild with forged internals and will run a direct port system starting with 100 shots.
if anyone plans to run dry kit, you would definitely need to upgrade your injectors if you plan to spray more than 50 shots and you'll need an engine management to richen the injectors when it engages.
personally, i would think a wet kit or a direct port will be best.
His baseline was only 75whp? That sure does seem low sure there was not problems before he started?
AlanSRT4 is offline   Reply With Quote
Old 08-26-2009, 05:26 AM   #61
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Thats about right hp numbers for and auto dyno pull
Old 08-26-2009, 10:51 AM   #62
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Never said anything about WHP base line he was spraying a 75 shot when he spun the rod. His base line is probably where anyones is with a couple bolt-ons
Old 08-26-2009, 11:23 AM   #63
blacksandiegovitz
Drives: 08 Vitz
Stock auto yaris , with nothing but spray , I'd say 77 whp sounds dead on for a stock auto
Old 08-27-2009, 12:16 AM   #64
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
well, my stock automatic Yaris Sedan pulled a 81 whp which I think is about right for a standard stock car.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 09-18-2009, 10:36 AM   #65
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Can we make this a sticky?
Can I merge this with The Nitrous Thread?
Thread cleaned, merged and stickied.
Old 10-23-2009, 12:58 AM   #66
frownonfun
frownonfun's Avatar
ok so i've read through this whole thread and i'm still not sure what the consensus is on where the best place is to spray the nitrous. is it pre TB or right after or into the intake manifold? would i be fine injecting it into the tubing directly before the TB? i thought i read in one of these posts that someone had successfully done that or recommended it if running a s/c.
I crush you like tiny clown car, because you are clown, yes?
Old 10-23-2009, 04:44 AM   #67
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Dry kit you would run it before the throttle body. Wet kit after the throttle body, would you want a pool of nitrous stuck inside if some gets caught on the throttle body and just drips into intake..
Old 10-23-2009, 11:02 AM   #68
oooOOOO my first sticky My nipples just got hard!
Old 10-23-2009, 11:27 AM   #69
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
a pool of nitrous lmfao dude, since when was nitrous oxide a liquid in it's uncompressed state?
Originally Posted by xnamerxx
you nailed it sir.
Old 10-23-2009, 12:28 PM   #70
Nexus1155
Drives: Audi
builds up on the butterfly?
Old 10-23-2009, 12:42 PM   #71
Tamago
Tamago's Avatar
Drives: ZZW30
frozen water ?
because you guys are DBW, yeah i wouldn't recommend spraying super-chilled air past delicate equipment..
but a traditional setup wet or dry can be mounted pre-throttlebody.
you nailed it sir.
Old 10-23-2009, 12:42 PM   #72
lilredrocket
Slowy getting there
Drives: 08 Liftback
Then evaporates. I always thought a dry system was setup at the begining of the intake system by the filter. I believe zex even sells cone filters with a nozzle in them
Expressions and Explanations thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 0 11-09-2008 06:55 PM
The Official "Bambo the Yarisworld Traveler" thread (V1) nemesisz Off-topic / Other Cars / Everything else Discussions 3 11-08-2008 11:24 PM
Is there a thread about..... Letsrock Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-01-2008 01:25 PM
Thread request - Yaris is new in the US makaluch Cosmetic Modifications (Exterior/Interior) 1 08-13-2006 01:16 AM
