Old 04-11-2006, 03:12 PM   #1
SmellyTofu
好多人&
Drives: .
Inch up rubber
Has anyone put in 16" wheels on their car? What size tyres did you use? I find that the RS has 195/50R16 which is next to impossible to find any decent rubbers. 205/50R16 might be a bit too large on looks but every tyre is made in this size.
SmellyTofu is offline   Reply With Quote
Old 04-11-2006, 05:46 PM   #2
Sp33dY
www.OZTOYOTA.com
Drives: Toyota Echo
NOTHING wrong with 205 rubber... will look good :)
www.oztoyota.com - Australian Toyota ECHO and YARIS Club
Sp33dY is offline   Reply With Quote
Old 04-11-2006, 08:57 PM   #3
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Drives: 2008 Mazda3 S Sport
185/70/14 is just smaller than 205/50/16 (overall Diameter). You should be fine.
Code:
DiabolicJourney_SpaRky
DJ_SpaRky is offline   Reply With Quote
Old 04-11-2006, 11:34 PM   #4
Ron
Drives: BBM Yaris HB
base yaris tire sizing is 175/70/14. yaris RS sizing is 185/65/15. 205/50/16 sizes up to slightly bigger than the base sizing, but smaller than than the RS sizing in diameter, so you should have no problems at all. especially at stock height, yaris' are pretty much 4x4 height :D
Ron is offline   Reply With Quote
Old 04-12-2006, 12:24 AM   #5
SmellyTofu
好多人&
Drives: .
Actually, the standard for my car is 185/60R15 and no, it won't be at stock height. I've got a few hardware for the vehicle but missing the vehicle to put them on. I think I found my tyres anyway. Advan A048 in the standard 195/50R16.
Old 04-12-2006, 07:40 AM   #6
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Neovas are nice, I wish they sold them here, but I probably wouldn't get them anyways, too $$$$
Code:
Old 04-12-2006, 11:17 AM   #7
Ron
my mistake, sorry. base tire sizing is 175/65/14, RS sizing is 185/60/15.
regardless, a 205/50/16 is less than 10mm diameter larger than 185/60/16, so it should fit if you have a reasonable offset wheel (+38 to + 50 should work fine)
Old 05-03-2006, 09:35 AM   #8
Snake
Send a message via AIM to Snake
do you guys know if the stock tire sizing is programmed into the computer at 14" or 15" because there is a .75 inch difference in tire diameter between the two sizes. This can make a big difference in the speedometer reading.
Snake is offline   Reply With Quote
Old 05-03-2006, 04:45 PM   #9
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Have to assume that Toyota calibrates each car for the tire they are going to put on it.
Colin Chapman disciple
Old 05-07-2006, 06:55 PM   #10
Ron
i doubt there is any difference in the speedo calibration between the base and RS trims
Old 05-07-2006, 09:02 PM   #11
jcove
jcove's Avatar
Drives: 2011 Rogue
There's only a little over 3 % difference between the sizes. They may not even need to calibrate between them.
jcove is offline   Reply With Quote
Old 05-08-2006, 01:50 AM   #12
Snake
I put a set of tires from my scion, but they are a little bit wide
might go with somethin thinner for the next set of tires
225/50/15
I think 205's should be perfect for this car
they look pretty wide though, slow'd down the car a bit but made up for it on the turns
Old 05-08-2006, 06:54 AM   #13
jcove
jcove's Avatar
Drives: 2011 Rogue
225/50/15
That sounds sweet, 225's on the Yaris. If you go with the calculator I put up, 215's x 40 on 18's will work nicely, but I'm not sure if I want to sacrifice that much of the ride. Anyone running a set up something like this? I'm curious as to how good/bad the ride is. Mind you, my Talon was awful because the kid that had it before me cut the springs. I didn't have the time/money to change that. One of the many reasons I purchased the Yaris. Too much $$$$ to get the Talon back up to a resonable level to drive daily.
Old 05-08-2006, 12:54 PM   #14
Snake
car looks alot better with 225's
gives it a nice wide stance
Old 05-14-2006, 11:33 AM   #15
Ron
i'll be using 195/50/16 in the front, and 205/50/16 in the rears. only reason im staggering the tire sizes is because i got a great deal on some used 195's, otherwise i'd go 205/50/16 all around. 205/50 is way easier to find tires for than 195/50. tire rack is selling 205/50/16 z-rated kuhmo 711's for $48 a piece, 195/50/16 h-rated for $49 each :D
Are there any real adavantages to spoilers and 15 inch tires? nwdixieboy General Yaris / Vitz Discussion 5 02-17-2006 10:08 PM
