ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
One filament in the headlamp bulb.
Am I missing some detail about the Yaris headlamp bulb? On-line I was looking at different Yaris headlamp bulbs. The headlamp bulb is listed as 65/55W. But all I could see in the clear headlamp bulbs is just one filiment.
The yaris uses a 9003/H4 bulb with two filiments.
The DRL uses the low beam (at lower voltage) so, yeah if you loose a DR, replace the bulb ASAP. Last edited by RedRide; 09-05-2009 at 05:39 AM. |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
one of my headlights looks sad. is this why? one of the filaments died?
yeppers, you will not see the 2nd filament by looking through the headlight assembly.
Also, if one of your headlight look very DIM compared to the other, you could have a bad ground somewhere... check all your wiring. |
Half a Bubble Off Plumb
When a headlight does need replacing, it's best done in matching pairs. Replace one, and the two will probably not appear the same color and brightness.
Also, once one goes, the other is living on borrowed time.
ellenbetty
Found this at Candle Power Inc. Diagram shows 2 filaments. Front filament for high beam. Rear filament for low beam. Not the best diagram.
Interesting read. The PDF explains the "difference" between a 9003 and H4 and clears that up.
| Bulb Replacement Guide (led Sizes) | theFEVA | Cosmetic Modifications (Exterior/Interior) | 113 | 02-28-2017 01:02 PM |
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 07:40 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| Yaris Hi-Beam Light Bulb Type | jesse1000 | Canada | 3 | 01-11-2009 09:59 PM |
| The right fog light bulb exploded and cracked the lense | vacantj | DIY / Maintenance / Service | 1 | 08-01-2007 05:07 AM |
