Old 09-17-2009, 02:11 PM   #19
Tamago
Tamago's Avatar
Drives: UZJ100
and your purpose for destroying a 2009 yaris is? better handling? faster 1/4mile times? your logic amuses me so far, i want to hear why you're doing all this.
Old 09-17-2009, 03:06 PM   #20
arcticvitz
arcticvitz's Avatar
Drives: Base 09 White Yaris 3DR 5MT
Send a message via AIM to arcticvitz
I'm going to answer that question as if it were positive and not passive aggressive (can't quite tell really). "Destroying" is a relative term in the sense that to you it may seem like I am ruining a brand new car where as to me I'm simply adjusting it to suit my liking. All of us on this forum have an idea as to what our car should be in the end, many people probably think you "Destroyed" your Xa by painting it panda color and putting a turbocharger on it but that's exactly what YOU wanted and not anyone else. Isn't that what car customization is all about?
My logic when I first began tearing the interior of my car apart was that I wanted to turn an otherwise mild mannered econo-box into a true competitor at the track as well as an exhilarating weekend canyon car. Although I may not have the budget for a new motor and a custom turbo kit, I can afford to be creative and think of cheap yet effective ways of improving overall driving performance even if that means eliminating certain comforts like air conditioning and sound insulation materials. In conclusion, yes this is all about better handling and overall performance on a budget! Well, that and possibly to inspire others to appreciate their car and realize that the only limitations are one's own imagination. I guess I'm just a little more extreme than others?
Proud to purchase parts through
arcticvitz is offline   Reply With Quote
Old 09-17-2009, 03:22 PM   #21
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
i think you could spend the cash on better things than windows IMO
If this is just a straght track car then yea i guess
http://www.4055design.com
Old 09-17-2009, 03:30 PM   #22
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
well if hes gonna keep the windshield as glass, then im cool with it. least its not a death trap anymore. Thieves will have a harder time breaking lexan.
Check out my Build thread:
Old 09-17-2009, 04:46 PM   #23
arcticvitz
arcticvitz's Avatar
Thank you for being positive! It's refreshing to get encouragement instead of negativity
Old 09-17-2009, 06:33 PM   #24
Tamago
Tamago's Avatar
Drives: UZJ100
you're removing weight from the wrong end of the car.
Old 09-17-2009, 08:26 PM   #25
As an FYI, those rear windows only weigh 4.60 lbs. I have one from crashy sitting in my office and I just put it on the scale. If you want to save some serious weight, figure out some way to replace the doors. I couldn't believe how heavy they were when I pulled them off (I would estimate about 100 lbs each).
Old 09-17-2009, 08:30 PM   #26
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Yeah if this works out well, i would play with fiberglass and do everything over with it. Then you can get a turbo kit. piece it together for under $700 can be very easy if you're a good shopper...
Old 09-17-2009, 08:52 PM   #27
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
this is a HUGE undertaking to make your own lexan windows.... I would not suggest you using anything less than 1/4", else it'll break pretty easily.
Yes lexan is flexible, but you don't want your window popping out cause the adhiesive can't hold it cause its bent like a spring and you close your hatch/trunk lid. I could just see that... POP!!!!
I'd say take out the back window... lay the lexan over the top, and then heat it up and slowly mold it to the exact shape of the oem window.
Old 09-17-2009, 09:04 PM   #28
arcticvitz
arcticvitz's Avatar
Interesting! The rear window seems like it would be a much larger chore however bolting down the rear side windows would be much safer than adhesive I'm sure. I didn't know that lexan was so brittle if it was under 1/4" as well so thanks for the info!
Old 09-17-2009, 09:12 PM   #29
arcticvitz
arcticvitz's Avatar
In that case would your recommendation be to leave in the spare tire as well since it adds weight to the rear and makes a better balance? Losing 30 pounds of weight below the center of gravity in the rear probably makes a pretty profound difference as well does it not? If better handling means making the back end heavier since there's nothing left to pull out from the front then why not even put a sub woofer box back there on top of the spare tire and make it nice and heavy? Sure acceleration suffers but essentially that would give you a better weight balance correct?
Old 09-17-2009, 09:44 PM   #30
kngrsll
Apexing Egg!!
kngrsll's Avatar
i think its a cool idea.
but i am too lazy.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 09-17-2009, 10:41 PM   #31
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Damn they are light. Not worth it at all to save less than 8 pounds
Old 09-18-2009, 03:55 AM   #32
Tamago
Tamago's Avatar
Drives: UZJ100
what i'm saying was, that's an awful lot of work and risk for such a small amount of weight loss, especially when it's from the wrong end of the car. in this case a carbon fiber hood actually makes more sense
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Question: Installing Power windows! Syroyizhka DIY / Maintenance / Service 4 05-06-2009 09:29 PM
Question for LB owners with windows tinted myt Cosmetic Modifications (Exterior/Interior) 13 08-10-2007 12:44 PM
a question for those with tinted windows... static808 Cosmetic Modifications (Exterior/Interior) 52 02-08-2007 10:42 PM
Liftback seat question Goose General Yaris / Vitz Discussion 6 04-21-2006 12:29 PM
