Old 09-24-2009, 10:13 PM   #1
JapRulezz
JapRulezz's Avatar
Drives: yaris sedan 2NZ-FE
is there a solution?
does smears on the plastic gauge cover from dashboard polisher come off ?
i tried water , soap , alcohol , windex everything
if not where are they sold
JapRulezz is offline   Reply With Quote
Old 09-24-2009, 10:19 PM   #2
Smear of what? You can try Past-x by Meguiar's.
Old 09-25-2009, 11:37 AM   #3
JapRulezz
JapRulezz's Avatar
dashboard polisher on the transperent gauge screen in the middle made a whitish spot that wont come off
Old 09-25-2009, 07:07 PM   #4
http://www.yarisworld.com/forums/showthread.php?t=19538
I've gotta do something about what I think are Armor All spray splotches on mine.
Old 10-07-2009, 02:33 PM   #5
RevoluScion
Drives: tC
what polishers are you using for the dash?
JEFF aka 2BLU_tC - REVOLUSCION - El President
Team & Individual Sponsors:
MOTUL - SMARTWAX - K&N - AEM - TOKICO - R1 CONCEPTS - TOYO TIRES - CROSSFIRE - G2 AUTOSPORTS - M2- NRG - MISHIMOTO - ROTORA - VERTICAL DOORS - CLAZZIO - K&R DIGITAL - EURO LIGHTS - 5ZIGEN
we are a family oriented all Toyota brand Car Club! toyota, lexus, yaris & Scion Bienbenidos!!!!
RevoluScion is offline   Reply With Quote
Old 10-07-2009, 03:19 PM   #6
tomato
tomato's Avatar
I use Meguiar's non-shine polisher. Works great.
Old 10-08-2009, 03:29 PM   #7
RevoluScion
Drives: tC
well from what i heard by some pro's is that pretty much your going to need a new plastic cover now, specially after using so much other chemicals on it.
Old 10-08-2009, 08:03 PM   #8
severous01
3m plastic polish....found in the auto section of walmart or autozone. it's a small black container. you want the one with the pink label, not green.
Old 10-16-2009, 12:25 PM   #9
linny
Drives: '08 liftback mt
If it is a foggy spot (etched) you might get it out with brasso polishing compound. I have used it for years to make old snowmobile and boat plastic windshields clear as new. Just put some on the corner of a rag and rub it in. I first learned about this from a old watchmaker I worked for that used it to polish up plastic watch crystals. It is amazing stuff!
linny is offline   Reply With Quote
Old 10-18-2009, 12:43 AM   #10
RedRide
RedRide's Avatar
Why are you guys polishing your dash?
Personally, I just keep a micro fiber cloth in the glove compartment and wipe the dash on ocasion. This keeps it looking new.
My Celica is almost 8 years old and has never had anything applied to the dash it and it still looks like new.
Old 11-07-2009, 05:47 PM   #11
Vang
Drives: 2008 Yaris Sedan
yes the plastx/ headlight restoration kit by meguirs (found at walmart/autozone) will clean that up!
Vang is offline   Reply With Quote
Old 11-07-2009, 10:16 PM   #12
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
So what does polishing the dash do? Hmm, maybe if mine was full real carbon fibre, but otherwise?
Colin Chapman disciple
Old 11-08-2009, 05:38 AM   #13
JetfireK
Drives: 2008 3 Dr Liftback
All you need to clean actually most anything inside and outside of your car are two micro rags......One of then wet with water and wrung out .....then use the dry micro rag to remove the water....and Presto You are finished.......No Fuss....No Muss....works great on house mirrors too....
JetfireK is offline   Reply With Quote
Old 07-30-2010, 08:20 PM   #14
Reebirt
Yota
Reebirt's Avatar
Drives: 2010 Yaris 5 door Hatchback
correct me if I am wrong. ... vinegar and water?
I also use baby wipes for interior dusting between serious detailing.
Reebirt is offline   Reply With Quote
Old 07-30-2010, 08:42 PM   #15
Chuck G
Drives: 2010 Yaris Sedan
Very wise words!!
Sort of, Kind of, solution to A/C Stench captainm27 General Yaris / Vitz Discussion 10 08-12-2009 08:01 PM
Solution to Static on Front Seats molinee Cosmetic Modifications (Exterior/Interior) 6 06-12-2009 07:30 PM
european dash solution? microbe__ In Car Entertainment + Electronics (audio / video / alarm) 3 11-19-2008 05:32 AM
Chevy's solution: copy Toyota shamelessly deebrown General Yaris / Vitz Discussion 45 05-03-2007 02:05 AM
