![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
FS: Dashboard Covers for the '07-'09 LB, ProClip Mounts, 180mm Double Din Trim Piece
FS:
Two Dash-Topper dashboard covers. Both are velour. One is black and the other dark gray. http://www.dashtopper.com/shop.net/VelourDT.aspx Both include all pieces they originally came with. The black one will come in its original box and packaging. The dark gray will come wrapped in a plastic bag in a brown box. Also, on both sets the piece that goes on the driver side glovebox has a hole cut in the middle (I have a Garmin GPS mount permanently attached to my driver side glovebox door and the holes were for the mount to stick through). ![]() ![]() ![]() $37 + shipping for each set. ================================================== ================================================== ====================== ProClip Angled Mount (fits LB only): ProClip Item #: 853742 http://www.proclipusa.com/?sectionpath=144&pageid=11575 ![]() ProClip Center Mount (fits both LB and Sedan): ProClip Item #: 853835 http://www.proclipusa.com/?sectionpath=144&pageid=11986 $17 + shipping for each ProClip ================================================== ================================================== ====================== Finally, I have one 180mm Double Din Trim Piece. I tried modifying it to work with my Pioneer head unit, but it wouldn't fit. Using a dremel, I shaved down the inner sides of the frame. It has a scratch on both of the bottom corners. I'm guessing if your good at working with CF or you like wrapping these trim pieces in vinyl or leather, this would be a good piece for you to work on. ![]() ![]() ![]() ![]() ![]() ![]() $34 + shipping for the 180mm DD Trim Piece ================================================== ================================================== ====================== My heatware for references: http://www.heatware.com/eval.php?id=35947 Last edited by IsLNdbOi; 09-10-2009 at 05:03 AM. |
Want to try this payment thing one more time?
I'd really like to get the vent mount from you. |
Ok, try it again. I'd take that picture down though. All of your personal information is visible.
I removed my street address from the screen shot. I'm really not worried about my city and last 4 digits to my credit cards.
P.S. If it still shows that I have an unverified address on your end I promised I won't dispute the charge. Not to mention when you send the package via a shipping company you will have a tracking number which will verify delivery and you could use that in your defense if I did a dispute you wouldn't loose any money. |
Payment sent
I'll take the angled LB mount. PM me!
Not sure what's up but the center mount that I received is about a half inch too small to fit in the vent.
As far as I can tell the clip should be just a bit larger then the entire height of the vent so that you can squeeze it and the pressure out wards (up and down) will hold the mount in. It looks like this one is warped or defective. I guess I'll have to see if I can heat up the plastic at the bend as to make it bigger so it will fit. |
ProClip Mount Doesn't Fit
Install Instructions
On the picture I uploaded the red line is showing you where my top clip lines up at when the bottom part of the clips is set and clipped in. Any suggestions? |
It's supposed to clip to the top and bottom of the AC vent. You're supposed to wedge the top edge of the opening for the AC and the bottom edge of the opening for the AC into the indentations / guides in the vent mount. That pressure is supposed to keep the mount stable.
#10 | |
I'll take a picture and post it up tonight. |
#11 | |
Any suggestions? |
Hmmm... I don't know. ProClips USA shows that it's compatible with the sedan. In fact, they only show it for the sedan. When you choose just the Yaris, it shows the other mount which says that it's not for the sedan.
Does that mount I sold you still have the sticker on it that shows the part number? |
I'm not sure if the center vents on the hatch and sedan are the same size. I thought that they were.
The clip was in used condition as you can tell something had already been screwed into it. Didn't you use this clip on your Yaris? |
I did use it in my Yaris in the past. Before sending it to you, it had been at least 4 months since I last used it. Not sure if you noticed, but I put foam tape on it because it was too tight (but not so tight as to deform it) and I didn't want it to damage the paint around the vent.
Is the sticker with the part number still on it? The only center / vent mount ProClips has is for the sedan. It just happens to fit the LB as well. |
SOLD!:
Gray Dash-Topper ProClip Vent Mount 180mm Double Din Trim Piece |
| Group Buy - True Double Din Radio Trim for Liftbacks (180mm opening) | CTScott | Items for Sale by private party | 259 | 06-08-2011 11:13 PM |
| FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece | IsLNdbOi | Items for Sale by private party | 2 | 08-23-2009 02:37 AM |
| True Double Din Radio Trim for Liftbacks (180mm opening) | cruz-gsr | Items for Sale by private party | 3 | 07-05-2009 11:02 PM |
| For Sale True Double Din Radio Trim for Liftbacks (180mm opening) | Adriaan | Items for Sale by private party | 0 | 05-25-2009 11:16 AM |
| Double Din 180mm Trim Bezel | esyres | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 03-19-2009 09:01 PM |
