Old 09-19-2009, 12:29 AM   #451
Originally Posted by AlexNet0 View Post
maybe I am just very slow, but I cannot find how to remove the top dash.
Check out the AC section of the service manual. Page 113 shows the screws you have to remove.
Old 09-19-2009, 12:42 AM   #452
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
here it is for those who dont have the manuals.
Old 09-20-2009, 10:04 PM   #453
AVIC-U310BT
Drives: 2007 Yaris Hatchback
Thumbs up Install worked perfectly!
I did the install with a stalk (Thailand eBay, $30) in my '07 AT Liftback. Everything worked on the first try and I am ready to enjoy a foot-cramp-free road trip next week. Thanks everyone involved in making this possible (especially CTScott and nickjhort)! Thirty bucks for cruise control is like Christmas coming early for me. Thanks again!
AVIC-U310BT is offline   Reply With Quote
Old 09-25-2009, 12:20 PM   #454
127.0.0.1
I am getting a 2010 5 door HB, anyone know if it is plug-n-go ?
If not, I will be one of the first to report about it. When I get the thing I will
check for the appropriate pre-wired condition.
Old 09-25-2009, 12:58 PM   #455
It will work just like 09's. I have the 2010 EWDs and everything with cruise is the same.
Old 09-29-2009, 11:57 AM   #456
127.0.0.1
sweet. I am going to go to electronics-r-us and get NO switches
and mygyver it the no-air-bag method.
delears wants a LOT of loot to add cruise control, probably based on what it
costs for a full install. plus more.
screw that.
Old 10-03-2009, 10:18 PM   #457
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Installation of CTScotts LED Module for DIY Cruise Control
Wasn't sure where to post this...a new thread or here...
1. Disconnect negative battery terminal...
2. Remove all plastics around radio and then remove gauge cluster...
3. Remove two screws in front of the gauge cluster...
4. Remove screws in both cup holders...
5. Remove glove box. Open and pop out tabs on both sides...
6. Unplug yellow airbag connector and remove two bolts with a 12mm socket...
7. Make sure you have a long socket (this one's a bit overkill) or you will knock your knuckles (it hurts) the bolts are tight...
8. Remove A-pillers. Pull back the rubber casing and pull them right off (gently)...
9. And there you have it...that's all that holds on your dash...now just pull that sucker out...
After that it's pretty much cut and splice wires to insert the Module.
10. Choose a spot to mount the module. I put mine in between the center vent outlet and the radio.
11. Connect the wires to their appropriate counterparts.
Connect the LED wires to your LED (duh)
Connect the ACC power wire to any source of ACC power (any wire that gets 12 volts when you turn the key to the ON position). I chose the pink one on the steering column (ignition connector)
And finally connect the Switch power wires. The red to your wire going from the switch to the ECM and the black to any grounding point.
12. And there you have it. Hook your battery back up quick and test it to make sure it works (unhook the battery again before you plug your airbag back in) then put everything back together.
I put my LED in the gauge cluster to make it look semi-stock. I used a white LED and scrapped a little hole in the black paint on the face plate inside the plastic housing. You can see the white dot right under the trip meter reset button. You can't even see it until you hit the CC switch so it's kind of hidden.
Hope this helps anyone planning on doing something similar. I know CTScott said he would sell these modules for $25 or so. It's a very easy install and I recommend it so you don't always have to wonder "did I already turn it on?" Let me know if you have any questions.
Video...
http://s236.photobucket.com/albums/f...t=CIMG7073.flv
My Car Rules!
nickhjort is offline   Reply With Quote
Old 10-08-2009, 12:03 AM   #458
sex
sex's Avatar
Drives: 09 5DR
Install for 2009 5DR Auto w/Power Package
My own experience:
I used a stalk from an '05 Solara which had a cable attached to a 12-pin connector. I had to de-pin the two cruise control wires.
1. Disconnect negative cable from battery using 10mm socket wrench.
2. Unscrew left and right T30 bolts to unfasten airbag.
3. Lift airbag off steering wheel and gently pry up the yellow locking tabs.
4. Remove horn cable from clockspring and disconnect from airbag.
5. Lift locking tab from connector and insert the two stalk wires.
6. Drilled out rear steering wheel cover by aligning stalk and eyeballing position.
7. Fastened stalk, seated cable into clip, and plugged into clockspring.
8. Plugged in airbag, secured bolts, and reconnected battery.
sex is offline   Reply With Quote
Old 01-15-2010, 12:55 AM   #459
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Bump!
I just spent 2 hours reading this *whole* thread. Wow. You guys are awesome... I love these pioneering threads. So much excitement and discovery... reminds me of the Blitz install threads from the summer of '08!
I just bought a stalk for my Canadian '06 hatch (RS). I figure I'll be running wires to the ECM. But how I would love it if the RS trim happened to have the dash lights already!
In fact, I'm going to go out into the garage right now *brrrr* with a flashlight and find out! (Won't be doing the install until warmer weather though!) -- EDIT: Nope... no dash light.
Anyhow, thanks to all... YW FTW!
2006 Red Blitzed RS 5-door
Old 01-15-2010, 02:12 AM   #460
goku87
goku87's Avatar
Drives: Black HB
Woah woah woah woah woah, where did you get those?
Think you can get the rest of the factory repair manual?? :D:D:D:D
goku87 is offline   Reply With Quote
Old 01-15-2010, 09:28 AM   #461
Toyota techinfo. Unfortunately, because of the way they serve the data, it is nearly impossible to grab the entire manual, but I have the sections for the 2009 and 2010 that differ from the 2007 manual (TPWS, VSC, TRAC, etc.)
Old 01-15-2010, 03:39 PM   #462
goku87
goku87's Avatar
Drives: Black HB
I didn't even know that site existed. NEAT.
Old 03-17-2010, 05:47 PM   #463
stvee
Drives: 09 sedan
Is the wire included if I order one of these from toyota parts zone?
84632-08021
Two months old and all, but this seems like the thread to beat.
stvee is offline   Reply With Quote
Old 03-17-2010, 05:56 PM   #464
84632-08021
No, you also need to order 84633-02020 to get the wire.
Old 03-19-2010, 04:58 AM   #465
stvee
Drives: 09 sedan
I know I'm getting off light because I'm an 09, but how much harder is it to replace the steering wheel wheel cover rather than drilling the hole? Fear of the clockspring seems to be a recurring theme in these threads.
Old 03-19-2010, 08:49 AM   #466
It's really not that bad. I pulled my steering wheel recently to install the leather steering wheel that I bought from a member from Germany. You just want to be careful with the clock spring, as it is quite expensive (>$200).
Old 03-23-2010, 06:00 AM   #467
stvee
Drives: 09 sedan
Parts are pretty close and I'm still trying to get up the nerve to do this myself.
Could you be a little more specific about being careful with the clockspring? From this thread it looks like the biggest concerns would be not spinning the clockspring and not damaging the wires coming out of it. What else do I need to look out for?
All this cause I don't want to pay a guy a hundred and fifty bucks.
Old 03-23-2010, 08:59 AM   #468
Those are the main concerns. Also, the clockspring's plastic is somewhat fragile, so just be careful not to smack it while working around the steering column with the wheel removed.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 02:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
