![]() Drives: 5 dr Yaris LB Join Date: Mar 2009
Back wiper
When I turn on the rear wiper in my hatchback, it makes this god awful noise like its not moving smoothly across the window. It just sounds like rubber skidding across glass. Anyone know how to stop this so I can leave the wiper on when it rains?
pink wheels are cool
soak the blade in vinegar it will losen it up
or it will break in over time |
![]() ![]() Drives: 05 Echo H/B Join Date: Jul 2009
I soaked my other car's wiper in vinegar and it works like a charm :)
you guys are serious? soak in vinegar?
Anyhow.. when i had my hatchback, my windows had always been treated with RainX, never had probs.. |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Ya, it didn't get my hard water spots, and it didn't really help with a sunburn. I think people are just mean spirited and want you to smell bad on top of your initial problem.
But I guess its supposedly true: http://www.thriftyfun.com/tf48399082.tip.html |
![]() ![]() Drives: 2 Yaris Hatchbacks Join Date: Dec 2006
You could try cleaning the rubber part of the blade with a paper towel soaked with windshield washer fluid. The rubber oxidises a bit with time, and this can remove some of the oxidation. And if the glass has water spots, you could try using a clay bar to remove them from the glass. But I personally just leave the rear wiper off, and just turn it on for a single wipe or 2 every now and then manually.
mine only makes a little noise until i run some of the washer fulid and then it gets real smooth sounding...i just assume there is debris on the rear window that causes friction but, once the fluid gets in there it's all gravy...
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
After I wax my car I use the wipe off cloth to wipe my windows. It leaves a wax film and the wipers wipe better.
constantly changing
Drives: 2008 Toyota Yaris lb Join Date: Aug 2009
when that happened to mine i just simply turned the wiper around. its worked fine ever since.
_______________________________________________ |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Learn to Relax
I have the same exact problem with my rear wiper.
The rear wiper blade rubber really does seem stiffer then the front. I wiil try the vinigar trick before replacing the rubber with some stock I already have on hand, that is used but, is stiil servicable. |
| Removing rear wiper | fred812 | Cosmetic Modifications (Exterior/Interior) | 34 | 01-27-2013 01:22 AM |
| Looking for GTA HB to test Axle Back System | RaptorRacing | Canada | 8 | 11-29-2008 12:14 AM |
| So we just came back from TRD Thailand... | eTiMaGo | Performance Modifications | 28 | 03-21-2007 06:52 PM |
| Rear wiper function, is this normal? | Yaris Dick | General Yaris / Vitz Discussion | 7 | 11-08-2006 10:46 AM |
