#19 |
Reluctantly Crouched...
Anywhere from 1 to 2 degrees of negative camber up front should give a nice street set-up. You can purchase non-adjustable camber bolts from rockauto.com very cheap. I'm not sure how much, if any adjustment you can make without the use of camber bolts. While 0 degrees toe-in is preferred for performance, a very slight toe-in (1/16") will make the car track much better at highway speeds.
#20 | |
#21 |
Beast
we need a real 1 incher on the rear...
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#22 |
stock set up should produce -1 degree if adjusted for that.
#23 |
Beast
im talking bout an inch swaybar
#24 |
Thanks but no thanks...
#25 |
![]() ![]() Drives: Yaris 09 T-spirit 1.33 Join Date: Jul 2009
why do you change the camber bolts? what do they have different from stock?
#26 |
Beast
you can easily get more +/- camber with new ones
#27 | |
toe in = high speed stability.
#28 |
Tamago is correct, toe out improves turn-in, not tracking straight. Toe-in basically points the wheels towards each other, so the car is "trying" to steer to the center, toe-out has both wheels pulling away from each other, or constantly "fighting" each other. Whichever way you favor, the car will move more quickly in that direction.
#29 | |
The stock bolt you replace is exactly that; a regular bolt that doesn't have adjustability. I hope that helps. |
#30 |
#31 |
Hi all thanks for all the help, so first a get the yaris aligned, then i do the rear sway bar! what will the front upper strut do? will it help?
as far as the alignment what is the factory setup? i think the garage guy will know but better if i know so i'll tell him thanks all for the help |
#32 | |
the rear you can't mess with without shims. go read the "ultimate suspension guide" before you throw money away on a front upper strut bar.
| Tamago's guide to ultimate yaris handling | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 99 | 01-25-2026 12:51 PM |
| 24mm sway in front and 23mm in the rear | fuji | Performance Modifications | 28 | 11-13-2012 05:02 AM |
| Positives and negatives to hub spacers? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 11-11-2009 07:37 AM |
| In regards to understeer....... | anonymous user | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 56 | 05-31-2009 10:38 AM |
| Taking to next level and eliminate understeer | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 23 | 05-25-2009 07:19 PM |
