Old 09-30-2009, 11:07 PM   #37
You can't get crimp on resistors, but you can crimp them onto the wire (I believe it is 22 AWG) with butt splices.
Old 09-30-2009, 11:21 PM   #38
birdman
Drives: '08 Blazing Blue Yaris LB
Would a 1 or 1.5k resister do?
birdman is offline   Reply With Quote
Old 09-30-2009, 11:25 PM   #39
birdman
You have been very patient guiding me along to the point where I am confident enough to do this fix. Thank you thank you!
Old 09-30-2009, 11:36 PM   #40
Try the 1.5K, if that's what you have on hand. I tried 1k initially and then moved up to 2k. Even with a 10K resistor it will still illuminate.
Old 09-30-2009, 11:36 PM   #41
birdman
I just noticed that the diagram of the connector has "11" 3rd from the left while the photo shows the gray wire in what appears to be the 11 position not the 14th. Why is that?
Old 09-30-2009, 11:38 PM   #42
birdman
Is the higher number resister dimming the light more?
Old 09-30-2009, 11:43 PM   #43
birdman
I cant imagine where CT gets the energy to keep up with all the questions coming up. CT deserves a medal.
Old 09-30-2009, 11:43 PM   #44
The 11 vs 14 thing is because the connector drawings are from the perspective of looking into the end of the connector. In the picture we are looking into the back, so the pin numbers are mirrored.
A higher value resistor does dim it more.
Old 09-30-2009, 11:59 PM   #45
birdman
If I wanted to dim it down to a point where it's still easy enough to see during the day if the high beams are mistakenly left on what is highest number resister you'd use?
Old 10-01-2009, 12:28 AM   #46
I'd say 10K max.
Old 10-01-2009, 12:46 AM   #47
birdman
So thats what you'd personally use?
Old 10-01-2009, 12:47 AM   #48
birdman
I have a feeling we're reaching conclusion any time now.
Old 10-01-2009, 05:57 AM   #49
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Why not just cut out a little square of duct tape or electricians tape and stick it over the blue light.
Old 10-01-2009, 08:57 AM   #50
I am going to do this on my 09, when I have a chance, and will probably use somewhere between a 2K and 5K resistor.
Old 10-01-2009, 11:01 AM   #51
birdman
CT you're a champion!
Old 10-01-2009, 11:07 AM   #52
birdman
A cut out dot would obscure the light in a way that may make it hard to see when the brights are mistakenly on during the day.
Old 10-01-2009, 11:26 AM   #53
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
lol. CTSCOTT as always gives the perfect solution. and the OP wants an "easier" way out
i'm LOLing here
Originally Posted by xnamerxx
you nailed it sir.
Old 10-01-2009, 12:01 PM   #54
birdman
Easy and clear.
F/S Blue Stitched Leather Shift Boot. 1NZYaris1 Items for Sale by private party 9 05-07-2009 12:59 AM
Bayou Blue paint code andru47 General Yaris / Vitz Discussion 7 01-03-2009 05:19 PM
Blue Film over gauges Jeff1 DIY / Maintenance / Service 10 10-21-2008 04:01 PM
Black or Blue CrashRescueFF New YARIS Purchase Forum 18 07-24-2007 08:21 PM
Nautical Blue Metallic YotaYarisUSA General Yaris / Vitz Discussion 0 04-02-2006 08:09 PM
