#37 |
You can't get crimp on resistors, but you can crimp them onto the wire (I believe it is 22 AWG) with butt splices.
#38 |
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Would a 1 or 1.5k resister do?
#39 |
You have been very patient guiding me along to the point where I am confident enough to do this fix. Thank you thank you!
#40 |
#41 |
I just noticed that the diagram of the connector has "11" 3rd from the left while the photo shows the gray wire in what appears to be the 11 position not the 14th. Why is that?
#42 |
Is the higher number resister dimming the light more?
#43 |
I cant imagine where CT gets the energy to keep up with all the questions coming up. CT deserves a medal.
#44 |
The 11 vs 14 thing is because the connector drawings are from the perspective of looking into the end of the connector. In the picture we are looking into the back, so the pin numbers are mirrored.
A higher value resistor does dim it more. |
#45 |
If I wanted to dim it down to a point where it's still easy enough to see during the day if the high beams are mistakenly left on what is highest number resister you'd use?
#46 |
I'd say 10K max.
#47 |
So thats what you'd personally use?
#48 |
I have a feeling we're reaching conclusion any time now.
#49 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Why not just cut out a little square of duct tape or electricians tape and stick it over the blue light.
#50 |
#51 |
CT you're a champion!
#52 |
A cut out dot would obscure the light in a way that may make it hard to see when the brights are mistakenly on during the day.
#53 |
lol. CTSCOTT as always gives the perfect solution. and the OP wants an "easier" way out
i'm LOLing here
#54 |
Easy and clear.
| F/S Blue Stitched Leather Shift Boot. | 1NZYaris1 | Items for Sale by private party | 9 | 05-06-2009 11:59 PM |
| Bayou Blue paint code | andru47 | General Yaris / Vitz Discussion | 7 | 01-03-2009 04:19 PM |
| Blue Film over gauges | Jeff1 | DIY / Maintenance / Service | 10 | 10-21-2008 03:01 PM |
| Black or Blue | CrashRescueFF | New YARIS Purchase Forum | 18 | 07-24-2007 07:21 PM |
| Nautical Blue Metallic | YotaYarisUSA | General Yaris / Vitz Discussion | 0 | 04-02-2006 07:09 PM |
