Old 10-01-2009, 04:22 PM   #1
janel2007
Drives: 2007 Silver Yaris Sedan
oil changes
I am picking up a 2007 Yaris Sedan that I bought in a couple days. I read somewhere that the oil doesn't need to be changed as often as a regular car. Is this true?
Thanks,
Janel
janel2007 is offline   Reply With Quote
Old 10-01-2009, 04:51 PM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Welcome to YW.
The manual says every 5,000 miles. People tend to stick to this schedule until the end of their warranty period which is usually 36,000.
If you mean that it's up from every 3,000 miles, then yes, the oil changes have been extended.
I hope you enjoy your Yaris as much as everyone here.
Fumes.
Old 10-01-2009, 04:59 PM   #3
janel2007
Ok Thank you! Mine has 35,000 on it already so I will get one every 3000.
Old 10-01-2009, 05:29 PM   #4
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
Driving conditions have EVERYTHING to do with the oil drain interval. If you are doing most of your driving on the open highway and very little short trip type driving, then you might as well go with the 5000 mile interval, but if you are in town a lot and doing a lot of stop and go driving, a lot of idling, or if you hardly ever make trips long enough for your engine to really warm up good, then you should go with the 3000 mile interval.
Tom
YarisOwnersDad is offline   Reply With Quote
Old 10-03-2009, 09:44 PM   #5
Kal-El
Kal-El's Avatar
Thanks,
Janel
What's a "regular" car?
That made me laugh.
Huh??
Old 10-03-2009, 11:33 PM   #6
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
the normal is every 3k or every 3 months. I normally do it every 3-4k or every 3-4 months, and you figure you spend $30-$50 x 4 = $120-$200 a year. IMO the older engine oil is the worse it is.
RacerFreakXXX is offline   Reply With Quote
Old 10-04-2009, 12:33 AM   #7
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Please cosider Amsoil. I use Amsoil Dominator Racing oil and go 7-8k between changes. Amsoil for non racing aps can be used up to 15k even under severe conditions. For a lot of us that's just one change a year.
Check out Trulube.com for more info. I'm a dealer of Amsoil and use it in all my vehicles; F250, Honda Civic,and my Yaris. Plus 6 racing karts.
What ever you do, have fun with the Yaris!
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
