Old 10-04-2009, 08:30 PM   #1
POORSHA
POORSHA's Avatar
Drives: 2008 LB
cruise control not working
Finished wiring the factory cc stalk and clutch switch. cruise not working. What should i look for? What order would you start trouble shooting?
POORSHA is offline   Reply With Quote
Old 10-04-2009, 09:22 PM   #2
Triple check that your are really on pin 40 on the ECM to start with. post a pic of your ECM connection if you want an extra set of eyes on it.
Old 10-04-2009, 10:51 PM   #3
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I will double check monday. I used the repair wire from toyota and counted the pins. No cel so i don't think i put it in the mirror image pin. I i will look tommorow.
Old 10-05-2009, 02:27 PM   #4
POORSHA
POORSHA's Avatar
Drives: 2008 LB
wire hookups
here are the wiring hookups
Old 10-05-2009, 02:43 PM   #5
ECM Pin 40 and clutch switch connections look good. On the clock spring connector, I can't tell what you have connected. In the orientation of that picture the bottom right wire should be the ECM pin 40 one and the one above it should be connected to ground.
Old 10-05-2009, 03:34 PM   #6
POORSHA
POORSHA's Avatar
Drives: 2008 LB
ground should be below the horn, ecm to the left of ground? do we know were to get the pins for this conector ? I think the clockspring conector is not making good contact.
Old 10-05-2009, 03:50 PM   #7
Here's picture of the ground wire location (the brown wire).
The part number for the pin with a piece of wire attached is: 82998-12870
Old 10-05-2009, 06:54 PM   #8
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I ordered the pins and i will install them, I will also use a clutch wire jumper to make sure the switch is ok. Hope that fixes it.
Old 10-05-2009, 09:11 PM   #9
flutie98
Drives: Toyota Yaris
My only problem with the cruise was the clutch switch, jammin connectors in the terminals on the fusebox connections never worked. Went through every connection in the entire car tracking down a loose crimp or a short didnt find anything. So I used quick splice connectors and actually tied into the wires for the clutch-switch, works great now.
flutie98 is offline   Reply With Quote
Old 10-06-2009, 01:06 PM   #10
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Thanks I will look there today
Old 10-06-2009, 03:20 PM   #11
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Flutie, you were right. I reatached the clutch switch wires and the cruise works. Thanks to all those who came before with this diy.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
