offset for 7in on nf210s
Iv been doing some searches for Team Dynamics 15x7s, i dont know what offset i should go with. I have a 12mm spacer right now on my steelies, so i was thinking of combinations like 40mm and 12mm spacer, etc. Iv used http://www.1010tires.com/WheelOffsetCalculator.asp to help me decide. I do sometimes have about 300lbs in the back seat, and 250lb in front (me included), and if i do need to have more weight in the back, i could always swap to stock springs, shouldnt be too hard.
*whats the ratio when it comes to the stock height weight load and lowered car?
Reluctantly Crouched...
40mm should work with that spacer. With 15x7 wheels, you should have room to work with. I run 15x7 +35mm racing wheels with 205-50-15 Kumho XS's and NF210's, and I have room to spare all the way around. Even if I had a rear spacer, it would be fine.
if you go with +35 you'll probably rub a bit in the rear when carrying a lot of weight/passengers.
penguin garage rear camber shims would solve that.
| Offset and lowering on 205/45/16s | driver centric | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 08-13-2016 10:09 AM |
| hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? | tonyg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 03-19-2009 08:53 PM |
| Proper offset? | FA7 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-01-2009 08:37 PM |
| need 17inch rim guidence | chino_potato | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 46 | 04-09-2007 12:09 PM |
| max width and offset? | Fat Felixxx | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 06-08-2006 03:43 PM |
